Recommended source for a QA Bucket
/ Recommended source for a QA Bucket #1
indianaEPH
South Central Indiana
Kubota M59
I recently purchased a grapple bucket. That led me to converting the FEL to a QA system. I was going to convert my existing bucket to a QA by using a QA mounting plate. I started to do the conversion this weekend but I quickly determined that the the bucket would be compromised to much. The original pinned mount included a stiffening frame/braket which would be lost with the QA conversion. So I'm in the market for a new bucket.
Any suggestions for a good source? I'm in southern Indiana but I suspect I will need to get one shipped. I looked at Iowa farm Equipment and they look like they have a decent variety but I have not dealt with them in the past.
Everyone loves pictures so here is more grapple work today (rainy day):)
Thanks
Ed
/ Recommended source for a QA Bucket #2
I had a local dealer weld an ATI quick-tach plate onto the old pin-mounted bucket. works fine, but you might try Woods or Quicke for a solution.
/ Recommended source for a QA Bucket #3
I converted my Pin on to QA and it was not compromised in any way. If anything it is stronger now than it was with additional metal on top and with the plate welded onto the back..
BUT it was not real easy. It would be easier now for me to do it again., Much easier. The bucket you see in my Avatar is the original converted bucket. I also have a new 66 inch bucket too. But like the old one for heavy digging as it is narrower and stronger.
Perhaps this will help:
http://www.tractorbynet.com/forums/customization/208653-so-you-think-converting-pin.html
James K0UA
James K0UA
James:
THanks for pointing me to your link. THat was a lot of work. NIce job. I think it convinced me that buying a new one will be the right decision. I probably don't have the welding skill to pull it off.
/ Recommended source for a QA Bucket #6
ATI makes really nice buckets. ATI Corporation - Home.
Not cheap but great quality.
Used buckets + welding+ brackey usually = the same as a new one and the height is right so the loader arms dont drag.
Good Luck.
RD
/ Recommended source for a QA Bucket #7
Ed, do you want a 5', 6', or 7' bucket? I'm guessing you'd like a 6' bucket and maybe a toothbar, but you didn't specify in your post. I just saw a beautiful brand new 7' QA std. bucket, 1 yd, on craigslist that was a dealer take-off on a skidsteer. They wanted only $950 for the bucket (not cheap). You can be sure that the skidsteer bucket was very strong. 7' would probably be large for digging, but awesome for spreading and backdragging loose soil or gravel.
/ Recommended source for a QA Bucket #8
Check out your local Bobcat dealer. That is were I recently bought mine. They have all kinds of skid-steer buckets, but they also have buckets for their line of CUT's. I bought a 6' bucket for their CUT's to go on my JD4520 and like it very much. It is heavier duty than the John Deere standard duty bucket and was similar to their heavy duty version. Best of all it was only $750 no shipping.
Best of luck
Brian
/ Recommended source for a QA Bucket #10
Did you want a compact tractor bucket with a Skid Steer type mount or did you want a skid steer bucket? The reason I ask is the SS buckets have a long bottom matched with the SS's heavy curling cylinders. Having that long of bottom on a compact tractor with their small curling cylinders would limit the bucket's leverage.
I purchased Everything Attachments compact tractor general purpose bucket, with QA and Tooth Bar, have been very happy with my purchase. I would do business with this outfit again.
Here is a link to the bucket I purchased:
Construction Attachments General Purpose Compact Tractor, Loader, Standard Bucket, Universal Skid Steer Quick Attach, CAL, 1GPCMP
Thanks for the info. I will purchase the same thing. I don't want a true SS buck as the are to long and heavy.
Thanks for the help on this topic.
2022 EZ-GO ELITE...
2005 Ford F-150 Ext. Cab Pickup Truck (A61573)
2005 Ford F-150...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
(7) KUBOTA BRUSH GUARDS (A64280)
(7) KUBOTA BRUSH...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
SHORTWOOD 6 BOLSTER LOG TRAILER (A64276)
SHORTWOOD 6...
