stingray1
Veteran Member
- Joined
- Jun 21, 2012
- Messages
- 1,217
- Location
- East Tennessee
- Tractor
- John Deere 4200 w/backhoe, Ford 3000,Case 580 backhoe
Thanks Bob.
Straight 30W oil is generally recommended for small air-cooled engines. I have used multigrade like 10W-30 with no problem. My brother purchased a Enduro XT2 and told me he was using synthetic oil in it. That sounded like a good idea since I had some Mobil 1 10W-30 synthetic oil on hand. I changed the oil in my 2015 XT3 GSX 25HP Kohler with 200+ hours and used the Mobil 1. I parked it in the garage after mowing my 1 acre a few weeks later and found oil running across my garage floor. It appeared that the front engine seal was leaking. I changed oil and filter using straight 30W oil and so far it hasn't leaked again.
Bob B.
I believe in coincidences but I've had it six years now and it never leaked a drop anywhere until I changed to synthetic and it hasn't leaked a drop since I changed back to straight 30W. I did the second oil change last month using the 30W. I'm not going to push my luck and try it again.That is nothing but pure coincidence i use synthetic oil in high-mileage vehicles and high hours equipment for 25 years and also at work not once was there ever a problem.
Most modern day multi viscosity synthetics of good quality have very low VII and shear very litte they're pretty much considered a mono grade.
I would agree!I believe in coincidences but I've had it six years now and it never leaked a drop anywhere until I changed to synthetic and it hasn't leaked a drop since I changed back to straight 30W. I did the second oil change last month using the 30W. I'm not going to push my luck and try it again.
I may be a little gun shy because the final problem that caused me to trade in my 2004 3235 was the front seal went. I started losing a whole quart of oil mowing my 1 acre lot which takes about 1-1/2 hours.
Bob B.
Bob B.
