Recommended oil filter for 18hp Kohler Courage Engine (just purchased new).
   / Recommended oil filter for 18hp Kohler Courage Engine (just purchased new). #11
Thanks Bob.
   / Recommended oil filter for 18hp Kohler Courage Engine (just purchased new). #12
Straight 30W oil is generally recommended for small air-cooled engines. I have used multigrade like 10W-30 with no problem. My brother purchased a Enduro XT2 and told me he was using synthetic oil in it. That sounded like a good idea since I had some Mobil 1 10W-30 synthetic oil on hand. I changed the oil in my 2015 XT3 GSX 25HP Kohler with 200+ hours and used the Mobil 1. I parked it in the garage after mowing my 1 acre a few weeks later and found oil running across my garage floor. It appeared that the front engine seal was leaking. I changed oil and filter using straight 30W oil and so far it hasn't leaked again.
Bob B.
That is nothing but pure coincidence i use synthetic oil in high-mileage vehicles and high hours equipment for 25 years and also at work not once was there ever a problem.
Most modern day multi viscosity synthetics of good quality have very low VII and shear very litte they're pretty much considered a mono grade.
   / Recommended oil filter for 18hp Kohler Courage Engine (just purchased new). #13
I believe in coincidences but I've had it six years now and it never leaked a drop anywhere until I changed to synthetic and it hasn't leaked a drop since I changed back to straight 30W. I did the second oil change last month using the 30W. I'm not going to push my luck and try it again.
I may be a little gun shy because the final problem that caused me to trade in my 2004 3235 was the front seal went. I started losing a whole quart of oil mowing my 1 acre lot which takes about 1-1/2 hours.
Bob B.
   / Recommended oil filter for 18hp Kohler Courage Engine (just purchased new). #14
Bob B.
I would agree!
   / Recommended oil filter for 18hp Kohler Courage Engine (just purchased new). #15
Bob B.
Pure coincidence.
In six years there could have been any abnormal crankcase pressure any type of dirt and debris, mechanical failure in that seal to make it leak
3 weeks ago I picked up a 470hr big Cub Cadet with a Kohler 27 horse engine guess what went in yep Mobil 1 full synthetic no issues at all
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
Stump Grab Bucket (A50322)
Stump Grab Bucket...
3in Poly Pipe (A49461)
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A51039)
2020 Massey...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
