recommended lube for 3-PT ball fittings and similar
   / recommended lube for 3-PT ball fittings and similar #1
bellweather
Platinum Member
Western MA
Kubota BX22
What's a good lubricant for all those external parts that need to be slippery such as 3-pt hitch ball fittings, FEL engagement pins, and such?
Thanks
   / recommended lube for 3-PT ball fittings and similar #2
I save old drain oil, an mix it with a small amount of chain saw oil. That gives it some stickiness. Been doing that for years.
Army Grunt
   / recommended lube for 3-PT ball fittings and similar #3
I use Fluid Film. best stuff I have found for external coatings you want to stay for a while.
James K0UA
   / recommended lube for 3-PT ball fittings and similar #4
are you sure the ball needs to be lubed on the 3PH? i've been advised contrary (that part) as it will collect dust and accelerate wear.....maybe a silicone base?..everything else on it grease @ zerk. just imho
   / recommended lube for 3-PT ball fittings and similar #5
When I grease my zerks, any excess that oozes out, I swipe it out and wipe on metal parts that moves. I only do enough to coat it lightly, nothing more. If it gets dirty, just a simple wipe with rag takes care of it and I can wipe more on. There's always more where it coms from in oozing. :thumbsup:
Lots of good suggestions. Didn't know about Fluid Film, looks like great stuff. Bar/chain oil, that stuff is real sticky, sounds like a good option. As for whether those balls on the 3-pt arms should be lubed or not, while lube may attract some debris, going dry might cause more wear. How about spray-on lithium grease?
   / recommended lube for 3-PT ball fittings and similar #7
James K0UA
+1.:thumbsup:
   / recommended lube for 3-PT ball fittings and similar #8
JD manual recommends silicone spray. That's what I use. Doesn't collect dirt and dust.
Been getting plenty to make up what I've used at estate sales.
Ralph
   / recommended lube for 3-PT ball fittings and similar #9
Ralph
Jd Super Lube works great. I am pretty sure it just their version of silly spray.
   / recommended lube for 3-PT ball fittings and similar #10
I also use Fluid Film on those ball joints as well as other metal to metal contact parts that don't have Zerk's. Kinda like the smell of it too. :licking:
1983 Case 580D (A47477)
1983 Case 580D...
Set 4- 10-16.5 tires/wheel for bobcat (A53421)
Set 4- 10-16.5...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
2019 CATERPILLAR 262D3 SKID STEER (A52705)
2019 CATERPILLAR...
