recommended lube for 3-PT ball fittings and similar
   / recommended lube for 3-PT ball fittings and similar #1
bellweather
Platinum Member
Western MA
Kubota BX22
What's a good lubricant for all those external parts that need to be slippery such as 3-pt hitch ball fittings, FEL engagement pins, and such?
Thanks
   / recommended lube for 3-PT ball fittings and similar #2
I save old drain oil, an mix it with a small amount of chain saw oil. That gives it some stickiness. Been doing that for years.
Army Grunt
   / recommended lube for 3-PT ball fittings and similar #3
I use Fluid Film. best stuff I have found for external coatings you want to stay for a while.
James K0UA
   / recommended lube for 3-PT ball fittings and similar #4
are you sure the ball needs to be lubed on the 3PH? i've been advised contrary (that part) as it will collect dust and accelerate wear.....maybe a silicone base?..everything else on it grease @ zerk. just imho
   / recommended lube for 3-PT ball fittings and similar #5
When I grease my zerks, any excess that oozes out, I swipe it out and wipe on metal parts that moves. I only do enough to coat it lightly, nothing more. If it gets dirty, just a simple wipe with rag takes care of it and I can wipe more on. There's always more where it coms from in oozing. :thumbsup:
Lots of good suggestions. Didn't know about Fluid Film, looks like great stuff. Bar/chain oil, that stuff is real sticky, sounds like a good option. As for whether those balls on the 3-pt arms should be lubed or not, while lube may attract some debris, going dry might cause more wear. How about spray-on lithium grease?
   / recommended lube for 3-PT ball fittings and similar #7
James K0UA
+1.:thumbsup:
   / recommended lube for 3-PT ball fittings and similar #8
JD manual recommends silicone spray. That's what I use. Doesn't collect dirt and dust.
Been getting plenty to make up what I've used at estate sales.
Ralph
   / recommended lube for 3-PT ball fittings and similar #9
Ralph
Jd Super Lube works great. I am pretty sure it just their version of silly spray.
   / recommended lube for 3-PT ball fittings and similar #10
I also use Fluid Film on those ball joints as well as other metal to metal contact parts that don't have Zerk's. Kinda like the smell of it too. :licking:
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
