Recommended frequent starting of autos in sub-zero weather - how about tractors?
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #21
Yeah, start your car with you in it in the garage and let it idle for a short period, see if you die.
That's the idea.
Ralph
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #22
I still have the Coleman catalytic heater in the wife's car. We bought that while in Canada and it runs 8 hours on a tank of fuel and also has a space blanket in the kit. I may need it for warming the house someday due to power outage but doubtful that it will ever be needed here but doesn't hurt to be prepared I guess. My old Caddy that I had in Canada had no block heater or other cold weather starting aids and it cranked everytime even at -40 although it did require a little grinding on the starter to produce some heat to vaporize the fuel at -40 but anything above -30F it would fire right up.
I cant believe the news reported to go out and start your car every hour and run it for 10 minutes. I think I would stop viewing that station if I were you. All my vehicles get started whenever I want to use them and only then. My tractors may set for months without starting and never fail to start. When I worked out of the country, my cars have set for up to 8 months without starting and started right up although the batteries were a bit weak from parasitic drain. Tractors don't normally have any parasitic battery drain so no need to start them frequently.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #23
As well stated already, short engine runs are not a good maintenance strategy.
OP - You understand using a battery maintainer, so you have that covered - that is the way to keep the battery up, not briefly spinning the alternator.
If you are coming up to an oil change, consider using a synthetic for the winter, if you aren't already.
Rgds, D.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #24
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #25
I start them when I want to use them. The rest of the time they sit. I also use winter fuel in the tractor and high test in the Heep.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #26
Silly. Good way to run the battery down and crap up the oil.
Ralph
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #27
I have 2 nieces living 2 miles away. They tried the getting up at 2:30 last Thursday when the actual temperature was -33, started their cars and let them run for 15 minutes. At 8:00 it was -46 when they tried starting to go to work but neither car would start even though they had been warmed up. They called me and I drove them to work and their kinds to school. My answer is a heated garage. It costs money to heat but it does save wear and tear on the vehicles. Same with the tractor I run during the winter - it's in the heated garage.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #28
When you start a vehicle especially a cold one it runs the battery down. Unless you are going to drive for a while and recharge the battery you are doing more harm than good.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #29
the manual for my jd 4410 mentions an optional hydraulic heater in addition to the block heater. I don't have either but wish i did.
Great idea if your tractor is equipped to receive one. The ones I am familiar with install similar to a block heater.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #30
I live in central Ohio about a mile from the Indiana border. You can bet your bippy that I am not going to get up several times tonight to start anything. And if I do have to do so whatever equipment that required me to do this will be sold immediately.
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
202475 (A54757)
202475 (A54757)
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2022 Behnke Trailer (A55973)
2022 Behnke...
