Recommended frequent starting of autos in sub-zero weather - how about tractors?
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #21
Yeah, start your car with you in it in the garage and let it idle for a short period, see if you die.
That's the idea.
Ralph
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #22
I still have the Coleman catalytic heater in the wife's car. We bought that while in Canada and it runs 8 hours on a tank of fuel and also has a space blanket in the kit. I may need it for warming the house someday due to power outage but doubtful that it will ever be needed here but doesn't hurt to be prepared I guess. My old Caddy that I had in Canada had no block heater or other cold weather starting aids and it cranked everytime even at -40 although it did require a little grinding on the starter to produce some heat to vaporize the fuel at -40 but anything above -30F it would fire right up.
I cant believe the news reported to go out and start your car every hour and run it for 10 minutes. I think I would stop viewing that station if I were you. All my vehicles get started whenever I want to use them and only then. My tractors may set for months without starting and never fail to start. When I worked out of the country, my cars have set for up to 8 months without starting and started right up although the batteries were a bit weak from parasitic drain. Tractors don't normally have any parasitic battery drain so no need to start them frequently.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #23
As well stated already, short engine runs are not a good maintenance strategy.
OP - You understand using a battery maintainer, so you have that covered - that is the way to keep the battery up, not briefly spinning the alternator.
If you are coming up to an oil change, consider using a synthetic for the winter, if you aren't already.
Rgds, D.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #24
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #25
I start them when I want to use them. The rest of the time they sit. I also use winter fuel in the tractor and high test in the Heep.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #26
Silly. Good way to run the battery down and crap up the oil.
Ralph
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #27
I have 2 nieces living 2 miles away. They tried the getting up at 2:30 last Thursday when the actual temperature was -33, started their cars and let them run for 15 minutes. At 8:00 it was -46 when they tried starting to go to work but neither car would start even though they had been warmed up. They called me and I drove them to work and their kinds to school. My answer is a heated garage. It costs money to heat but it does save wear and tear on the vehicles. Same with the tractor I run during the winter - it's in the heated garage.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #28
When you start a vehicle especially a cold one it runs the battery down. Unless you are going to drive for a while and recharge the battery you are doing more harm than good.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #29
the manual for my jd 4410 mentions an optional hydraulic heater in addition to the block heater. I don't have either but wish i did.
Great idea if your tractor is equipped to receive one. The ones I am familiar with install similar to a block heater.
   / Recommended frequent starting of autos in sub-zero weather - how about tractors? #30
I live in central Ohio about a mile from the Indiana border. You can bet your bippy that I am not going to get up several times tonight to start anything. And if I do have to do so whatever equipment that required me to do this will be sold immediately.
AEREATOR (A58214)
AEREATOR (A58214)
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
(2) POLY ROLLING CARTS & CONTENTS (A58374)
(2) POLY ROLLING...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV4NPNJ0430, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
