Tires Recommended Fluid for tires
   / Recommended Fluid for tires #21
a burp valve would make that super easy..
burp between fills.
soundguy
   / Recommended Fluid for tires #22
I was thinking where I live in WV of going with about 35% methonal and 65% water.
That would be good to -15. I don't remember it ever being that cold for more than a day or so.
Think that would be OK Soundguy?
Being from somewhere near you, I can tell you that my tires froze once this winter with straight water. Even that only lasted about 10 min until it broke up. If you are on a budget, I would say you need minimal freeze protection.
Also, you can get Rimguard at Middletown in Fairmont and there is also someplace in Weston and Bridgeport. L&T here in Buckhannon uses Methanol and charges more than Rimguard. Not sure what Burrs here in Buckhannon sells.
   / Recommended Fluid for tires #23
When I was searching for adding weight I coverted my numbers to weight since in essence you are buying weight, not volume.
Rim Guard seems to me to be cost effective from what I have checked on. I had called a dealer last week and they said it would take about 110 gallons for a pair of17.5L-24R4 tires. Total cost would be $330. It would give me about 1200# (11# per gallon) total ballast. That is about .27 a pound. I also don't need a pump and valve as I would for window washer. I know Rim Guard is not readily availible everywhere so window washer fluid would be my second choice.
I know I dislike calcium for sure. You have to have a tube. It eats rims and nothing worse than getting a cut tire in the field and having a dead spot.
Window washing fluid at $1.20 a gallon and weighing around 8# a gallon will come in at roughly .15 a lb. You may have to buy a pump and a valve. I haven't priced either one of those items.
50/50 mixed antifreeze would be around .37 a pound. Now if you save your drained anti freeze or buy a used barrel of antifreeze from a car salvage yard you can get that down pretty cheap.
   / Recommended Fluid for tires #24
the pump and valve are a whopping 5$ a piece. and around here you can get antifreeze ofr free from auto shops.. thus you are investing time + 10$ if you went that route.
or time plus 10$, plus ww fluid sufficient enough to prevent solid freeze.. or same with something like rv PG af...
I loaded 2 16.9-24 fatty turf tires one morning while I was piddling arounnd my shop cleaning up.. used a cheapy burp valve and rv af.. mixed it thin... was cheap.. still better than air for weight...
soundguy
soundguy
   / Recommended Fluid for tires #25
I paid just under $200 for rimguard on 11.2 x24 tires. Should have done it when I first got the tractor. Non toxic, compatible with tire selant, weighs more than water/methanol mixes, won't corrode rims, and I don't think it's that expensive since you only do it once.
   / Recommended Fluid for tires #26
Hey wvpolecat,
I purchased that methonal in Spencer for $2.50 per gallon at Harris oil co.
If I figured right a 14.9 X 28 to be good to -15 which is the size I'm going to refill,
will only need 17.5 gallons of methonal which is only about $44.00 ea.
And I'm going from memory but I believe the 14.9 X 28 takes about 50 gallons of mix to fill at 75%.
As you said too, it could at the minimum. So I'm sure you could fill that size tire for a good bit less.
By the way I live in Clay County.
   / Recommended Fluid for tires #27
I would like to recommend a product called BOOST* with calcium chloride. It is Non-Corrosive, no problem with rim rot. It weighs more then 32% calcium and Beet Juice. 11.28 lbs. per gallon. Contact Dave at Great lakes chloride if your interested. daveb.glc@gmail.com
   / Recommended Fluid for tires #28
   / Recommended Fluid for tires #29
No it's not the simoniz sealtite ballast boost. This product is 32% Calcium Chloride, (Liquidow) with a corrosion inhibitor. It's a denatured molasses. We have used it in loader tires and tractors. Eliminated rim problems, should be price comparable with other liquids. More weight per gallon though.
   / Recommended Fluid for tires #30
interesting.. sounds like a combination of cacl and rimguard.. :)
soundguy
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
(5) Dura Trench Drain Grates (A56469)
(5) Dura Trench...
UNUSED FUTURE 32"...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
UNUSED JCT 96" PUSHER BLADE (A57193)
UNUSED JCT 96"...
24" PIN ON BUCKET (A52707)
24" PIN ON BUCKET...
