Tires Recommended Fluid for tires
   / Recommended Fluid for tires #12
I have heard of people using a mix of water and methanol. I don't know what the mix ratio is but locally methanol is $2.50 per gallon. I'm thinking of using that replacing the calcium ballast in one of my tractors if I can figure out the mixture.
   / Recommended Fluid for tires #13
I dont know how well this will come out. but here is a chart:
Methanol (METHYL ALCOHOL) Concentrate
Vol.% ---Freezing Point,F ---Flash Point,F
0----------32f--------No Flash
13---------20f --------130f
24---------0f ---------110f
35----- -15f---------95f
46 ---- -40f---------85f
56----- -65f---------75f
66----- -95f---------70f
75----- -115f--------60f
83----- -125f--------55f
92----- -130f--------55f
100---- -144f--------55f
Other tid bits about methanol:
Boiling Point: 147F,64C
Melting/Freezing Point: : -144F,-98C
Vapor Pressure: 760 Vapor Density: 1.1
Specific Gravity: 0.8
   / Recommended Fluid for tires #14
Thanks, your chart will be very helpfull.
If anyone uses methonal, be very carefull!!!!
   / Recommended Fluid for tires #15
remember.. you don't have to mix for ful freeze protection.. slushy is ok.. :)
   / Recommended Fluid for tires #16
I was thinking where I live in WV of going with about 35% methonal and 65% water.
That would be good to -15. I don't remember it ever being that cold for more than a day or so.
Think that would be OK Soundguy?
   / Recommended Fluid for tires #17
as i said.. slushy is fine.. solid you want to avoid.
sounduy
   / Recommended Fluid for tires #18
I checked around for prices to fill my 17.5x24 rear tires in MA and the first place I called that was closest to me wanted $$$$750 dollars to fill the two tires :confused2:
I called a place out in spencer (ahern power or something like that) and they quoted me $350 to do the tires :thumbsup: I was happy with that and since I ordered my grapple and valve kit through them I'm gonna have them fill the tires with Rimguard as well when they do the install. It will add about 1250 lbs total so I will be very happy with that.
If your tires are already filled that is a huge bonus, other than the high cost of Rimguard I don't see any disadvantage to it.
   / Recommended Fluid for tires #19
if you had the rimguard your self, you could fill them using a drill pump and save some cash.
filling tires is easy...
soundguy
   / Recommended Fluid for tires #20
I have a piece of 12" pipe with both ends welded up, a 2" fill fitting on the top with a 1/4" fitting welded into the bottom. Just add your fluid, hook up to your tire and pressurize the tank and the fluid goes right into the tire. The only thing you have to do is let the pressure equalize between each fill. The tank only holds about 6" gallons. So after your done with the methonal, hook up the water hose to finish it off.
I'll try and post a picture of it when I get home. The wife and I are on vacation this week.
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
183 (A52705)
183 (A52705)
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
