Recommendations hydraulic gages
   / Recommendations hydraulic gages #1
tractorblue
Van Alstyne, TX
New Holland TC35D
Looking for specific brand, model of hydraulic test gages. I own a NH TC35D, and pretty much a novice concerning hydraulics. If you have a specific model please advise part # or a link to a website. Thanks gentlemen! My 3PH will not raise and I've done most everything recommended on other threads. Frustrated but determined!
   / Recommendations hydraulic gages #2
You need a pressure gauge that has a max pressure at least two times your max system pressure. When valves close suddenly, the system pressure spikes and you can damage the gauge if the range is too small. I like liquid filled gauges because the needle is damped. You can get gauges at Surplus Center (google it)and you'll also need some hose and some adapter fittings "T"'s etc. You might need two gauges. Your service manual should tell you what tests to run and what's need to conduct the tests.
Have you checked the hydraulic filter? If your tractor has a suction screen, check that for clogging
Thanks Jerry; I'll check out Surplus Center, just ordered the service repair manual yesterday. I've checked fluid level, replaced both filters, checked the safety relief valve, replaced the rubber T hose just at a loss for now
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
