Recommendations hydraulic gages
   / Recommendations hydraulic gages #1
tractorblue
Van Alstyne, TX
New Holland TC35D
Looking for specific brand, model of hydraulic test gages. I own a NH TC35D, and pretty much a novice concerning hydraulics. If you have a specific model please advise part # or a link to a website. Thanks gentlemen! My 3PH will not raise and I've done most everything recommended on other threads. Frustrated but determined!
   / Recommendations hydraulic gages #2
You need a pressure gauge that has a max pressure at least two times your max system pressure. When valves close suddenly, the system pressure spikes and you can damage the gauge if the range is too small. I like liquid filled gauges because the needle is damped. You can get gauges at Surplus Center (google it)and you'll also need some hose and some adapter fittings "T"'s etc. You might need two gauges. Your service manual should tell you what tests to run and what's need to conduct the tests.
Have you checked the hydraulic filter? If your tractor has a suction screen, check that for clogging
Thanks Jerry; I'll check out Surplus Center, just ordered the service repair manual yesterday. I've checked fluid level, replaced both filters, checked the safety relief valve, replaced the rubber T hose just at a loss for now
KUBOTA M7-132 (A53084)
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2014 MACK CHU DAY CAB (A52472)
2014 MACK CHU DAY...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
John Deere 6120E (A50323)
John Deere 6120E...
