Buying Advice Recommendations for 40 acre vineyard
/ Recommendations for 40 acre vineyard #21
Went to a Kubota and New Holland dealer today. The salesman was talking about the Grand L40 series. Is the M series overkill for a 40 acre property with probably 30 acres in grapes? Looks like the L series is narrower. Anyone have an L4740 or L5240?
Opinions?
Thanks,
Rich
I went to an M8540 narrow for my vineyard but the main reason is that I needed to stay under 64" but needed the horsepower for my sprayer. What are the hp requirements of your sprayer?
I am still looking for recommendations on what equipment people are using and what is working well and not so well for vineyard owners/managers. Based on what other growers in the area are using, I am thinking of the Arbus 500 (20HP min.) or a 200 gallon sprayer. What sprayer are you using? Pros/cons?
Recommendations?
Thanks as always,
Rich
/ Recommendations for 40 acre vineyard #23
I am currently running an old FMC 400 gallon Economist. Will be upgrading possibly next year to a 400 gallon Turbo-Mist. I've actually considered going to a 2 row sprayer but that is because in my area the rain can come in fast and often so we have short spray windows and I need to cover as much ground as I can as fast as possible. That is why I won't use anything less then 400 gallons. You spend too much time filling the sprayer. I put 100 gallons of water on per acre so I cover 4 acres between refilling. It works good too because most of my blocks that are further away from my filling area are all 3-3.5 acre blocks so I can fill up, spray the entire block then run the tank out on the larger block before refilling then repeat.
What other equipment are you wanting to know about? I have a 1 ton Vicon mounted on a cart for banding fertilizer, I have a Green Hoe Company weed spray bar that I mount on the front of one of my tractors that is currently plumbed into a 3pt 60 gallon sprayer for weeds (I am working on a twin tank trailer for weed spraying so I can spray row middles with one spray and under the canopy with a different spray). I use a Bush Hog 295 rotary cutter for chopping the trimmings, an old Massey Ferguson 3pt auger for large end posts and a Shaver post pounder mounted to the middle of my Farmall for replacing broken posts. Out side of that anything else is usually custom made unless your going big with mechanical harvesting.
Tractor wise for the vineyard I run a Ford 1920, Case-IH Farmall 45A and a Kubota M8540 Narrow.
/ Recommendations for 40 acre vineyard #24
I don't think the Kubota M would be overkill for 30 acres of orchard but either the M or the larger Grand L would work. Your tractor probably should not be larger than 60-64 inches wide which will influence you. The Deere 4520 or 4720 would also work well with R1's on it too. Obviously the narrow vineyard tractors would be great too, they just cost more. With that much acreage you will be spending a lot of time in or on the tractor so creature comforts will make a big difference at the end of the day. If you have the budget, a cab makes a huge difference. I happen to be a fan of HST transmissions because of their infinite speed adjustments but that's a "nice" feature and not a requirement and not available on larger Hp tractors. Robert_in_NY has good advice and a nice range of tractors for all around work.
Thank you for the recommendations. A little more research and I think I am leaning towards the L5740. I see the M series does not offer the HST - probably a necessity as this is my first tractor. I can't hit the side of a barn with a shotgun, but I bet I can with a tractor...
Do you know why the 5740 has 57/50 while the 5240 has 52/45 when the engines seem the same except for 2700 vs 2600 rpm?
Thanks again,
Rich
/ Recommendations for 40 acre vineyard #26
i don't like spraying with hst because you can not have set speeds like gears and cruise control is not always that precise on my l3400. Its sort of hard to press the pedal for a long time while you are in your rows and it is difficult to maintain a constant speed.
Thanks for all your help.
I had the L5740 delivered the other day. This is my first tractor so I don't have anything to compare it to but so far -
I Love It!
Thanks again,
Rich
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
213121 (A64276)
213121 (A64276)
