Receiver Hitch Question
/ Receiver Hitch Question #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I am putting a 2"receiver hitch in the 3/8" thick butt plate of my winch. I run it on a 30 hp L3010 tractor that weighs about 5000 lbs. My little dump trailer is 4' X 6' and is rated for a 3000 lb payload. Can I just weld the receiver tube into the plate with a circumference bead on both the front and back sides, which was my plan, But not knowing about these things I wonder if I need some additional bracing ?? The tube is 2-1/2" X .220" that I got at a friendly welding shop. I cut it 5" long and it will barely protrude on the front side. Thanks.
gg
/ Receiver Hitch Question #2
should be fine but if it has any directional weight a couple of gussets weld on it will help.
/ Receiver Hitch Question #3
It would most likely be fine but I would add a piece of 2x2x2 angle iron on the underside at least, the tongue loading if you get to bouncing in the woods could be high;
also when towing a trailer on anything 3 pt mounted I would strongly recommend a stay chain from the drawbar mount to at least one of the lift arms to prevent the towed item from pushing into and possibly lifting the lift arms, it doesn't happen often but you can get the lift arms shoved right up into the tractor as they do not have an upward travel stop.
/ Receiver Hitch Question #4
I would add a gusset to the top and bottom just to be safe. Maybe a triangle piece vertical on top and sideways on the bottom.
Thanks for the suggestions. I have no feel for the kind of forces that occur in a trailer hitch. I wanted to keep the bottom clear if I could to make it a little easier to put the pin in since it is up behind the plate. So this is what I ended up with.
gg
/ Receiver Hitch Question #6
gg
[insert beer icon here]
/ Receiver Hitch Question #7
gg
Looks good should pull anything you hook to.
/ Receiver Hitch Question #8
gg
Does look good. The only thing I would or do add on these is a 3/8" band around the outer part of the receiver. Adds strength to the outer edges so you don't damage during a jack knife or tight turn. Most receivers have the band around the outer. I have a piece of the next size larger tubing that I cut the 3/8" band off of and weld it on. You may be ok without it. Good Job !
OK, I understand what you are saying. Thanks for the comment. I always wondered if those bands had a purpose or were just for dress - now I know. Always learn stuff here. The picture is actually the back end of the hitch tube. The trailer side is recessed pretty much into the butt plate so the logs won't catch on it as they swing and rotate around. Here is the working side. Would you suggest I need to change anything ??
The little 1-1/4" hitch on top I bolt on when I want to pull the wood splitter. When I am skidding logs it is not there. Same for any 2" ball.
gg
/ Receiver Hitch Question #10
gg
Good to go in my book. Nice job !!
/ Receiver Hitch Question #11
Nice job, gg!
/ Receiver Hitch Question #12
Looks great :beer:
/ Receiver Hitch Question #13
gg, this probably isn't saying much but I would be dang proud of that! :drink:
Thanks all for the compliments. I appreciate it very much. I know I will never be able to do the consistent quality work a real welder routinely does but I keep trying to do better. I am just happy that I can make some simple and useful stuff now. A very handy thing to be able to do. I wish I bought a welder 50 years ago.
gg
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
Informational Lot - Financing (A63689)
Informational Lot...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
F-250 Super Duty 4WD 6.2 (A63689)
F-250 Super Duty...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
