Receiver Hitch Adapter
/ Receiver Hitch Adapter #1
sheepman
SW Minnesota
1962 Fordson Super Major Diesel, 1951 Ferguson TO20
I was tired of always removing and installing trailer balls on my DX40, so I came up with this adapter so I can use the many receivers I have for my truck. It's simply made out of tubing, angle iron and flat stock I had lying around the yard. It slips over the drawbar and is secured by a pin in one of the small holes in the drawbar. Then I slide in the receiver and pin it normally. I attached a few pics so you can see how I made it.
I enjoy reading the posts on the site, and thought I could share something I did to make life easier.:D
Sheepman
/ Receiver Hitch Adapter #4
Great pictures and project. I was thinking of doing something with a receiver hitch on the drawbar but didn't have any plans. Yours is just what I was looking for. Quick on and off, simple and very functional. Using the hole farther back on the drawbar was an idea I didn't think of.
/ Receiver Hitch Adapter #5
Nice idea Sheepman. Here's another plan that's worked very well for us.
/ Receiver Hitch Adapter #6
Two very good ideas. How is the clearance for tight turns? I have a Kubota 7510 and was wondering how much the drawbar will support. I have a 20' boat to move around and need something dependable. Thanks
The clearance would be basically the same as if you just used the drawbar since the receiver adapter sits on top of the drawbar. The only difference is that the receiver ball is maybe 4" further back than if you just used the drawbar.
I don't know how much weight the drawbar would hold, but my adapter should support whatever the drawbar does. I don't generally pull anything too heavy, so I never really thought too much about it.
/ Receiver Hitch Adapter #8
Project,
You should be able to look up the spec's for your tractor's drawbar.
David from jax
/ Receiver Hitch Adapter #10
a big boat, but balanced on the trailer properly, the tongue weight is small
/ Receiver Hitch Adapter #12
Sheepman
I copied your idea and made a similar receiver hitch for my JD. Now the hitch height is closer to standard trailer height of 16". Works great.
/ Receiver Hitch Adapter #13
Dang, I need another project like a hole in the head. But that is just too good an idea and so simple. Excellent. Thanks!
/ Receiver Hitch Adapter #14
This is how I did it and use the 3ph to raise.
/ Receiver Hitch Adapter #15
Looks great. I may make one if I have to pull trailers aa distance, but I just love the ability to back up to a tailer and pick it's ball up with the 3pt hitch adapter.
Andy
2003 Ford Winstar (A64557)
2003 Ford Winstar...
John Deere 544K Articulated Wheel Loader (A64553)
John Deere 544K...
2002 JOHN DEERE 330C LC EXCAVATOR (A65053)
2002 JOHN DEERE...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2022 EZ-GO ELITE...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
