Rear Finish Mower Rebuilding my 72” King Kutter Finish Mower
   / Rebuilding my 72” King Kutter Finish Mower #1
espacef1fan
Shopping for a tractor
Started working on my finish mower today. I decided to paint it as there was corrosion starting especially under the deck.
The plan is painting the deck Massey red and the gearbox/ mounting plate Massey gray. I might paint the hitch brackets Massey gray or black I haven’t decided.
The pulleys and swivel assemblies will be black and the wheels silver.
Today I replaced a missing baffle and painted the underside to help slow/stop the corrosion. I chose white to make it easier to see while working under there in the future.
   / Rebuilding my 72” King Kutter Finish Mower #3
I think white under the deck is a good idea. Looking forward to seeing how the top turns out.
My thoughts on the white were:
- Cheap/easy match
- provides good light when working under it
- Will show trouble and dirt sooner/easier.
Update!
Current pricey casualty list:
- anti scalp roller
- blade spindles
Lots of little issues but nothing terminal.
   / Rebuilding my 72” King Kutter Finish Mower #7
Switched to Oregon gator G5 blades. Saw an improvement in cut and less hp loss with a 6’ Wood rd7200.
Got a part number on those blades?
Also figured out axles and wheels bushings were shot.
Fortunately replacement bushings are available for $30 on Amazon and includes enough to do all 4 wheels.
Axles were cheap through Rural King.(3/4x5 bolts with a very short thread and long grip)
   / Rebuilding my 72” King Kutter Finish Mower #10
591-585. Blades have three holes. My blades mount using two bolts to the spindle.
Had a hard time with caster wheel spindles bending and wear. Scut 4x4 in rough terrain and lots of back and forth maneuvering. Changed to 3500# axle bearings, spindles and hubs. At the the time 1/3 of cost of OEM parts. Did require some fabrication and welding. Been trouble free ever since.
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
XCMG CV83PD (A53317)
2018 Bell B30E 30 Ton Articulated Dump Truck (A55973)
2018 Bell B30E 30...
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
