Rear Finish Mower Rebuilding my 72” King Kutter Finish Mower
   / Rebuilding my 72” King Kutter Finish Mower #1
espacef1fan
Shopping for a tractor
Started working on my finish mower today. I decided to paint it as there was corrosion starting especially under the deck.
The plan is painting the deck Massey red and the gearbox/ mounting plate Massey gray. I might paint the hitch brackets Massey gray or black I haven’t decided.
The pulleys and swivel assemblies will be black and the wheels silver.
Today I replaced a missing baffle and painted the underside to help slow/stop the corrosion. I chose white to make it easier to see while working under there in the future.
   / Rebuilding my 72” King Kutter Finish Mower #3
I think white under the deck is a good idea. Looking forward to seeing how the top turns out.
My thoughts on the white were:
- Cheap/easy match
- provides good light when working under it
- Will show trouble and dirt sooner/easier.
Update!
Current pricey casualty list:
- anti scalp roller
- blade spindles
Lots of little issues but nothing terminal.
   / Rebuilding my 72” King Kutter Finish Mower #7
Switched to Oregon gator G5 blades. Saw an improvement in cut and less hp loss with a 6’ Wood rd7200.
Got a part number on those blades?
Also figured out axles and wheels bushings were shot.
Fortunately replacement bushings are available for $30 on Amazon and includes enough to do all 4 wheels.
Axles were cheap through Rural King.(3/4x5 bolts with a very short thread and long grip)
   / Rebuilding my 72” King Kutter Finish Mower #10
591-585. Blades have three holes. My blades mount using two bolts to the spindle.
Had a hard time with caster wheel spindles bending and wear. Scut 4x4 in rough terrain and lots of back and forth maneuvering. Changed to 3500# axle bearings, spindles and hubs. At the the time 1/3 of cost of OEM parts. Did require some fabrication and welding. Been trouble free ever since.
1965 Rogers Low Boy Trailer (A57453)
1965 Rogers Low...
1988 ASPT Patterson Trailer (A57148)
1988 ASPT...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
Trump 2028 Metal Sign (A57454)
Trump 2028 Metal...
