rebuilding lift cylinders on Deere 420 Loader
   / rebuilding lift cylinders on Deere 420 Loader #11
A chunk out of the seal generally isn't root cause, that might be why it will bypass or leak but figuring out what caused that is important. We see it happen time and again here, you reassemble the cylinder and it won't be long before another magical chunk is missing.
   / rebuilding lift cylinders on Deere 420 Loader #12
Yes, the OP'r will find a dent or score inside for the root cause.....:thumbsup:
   / rebuilding lift cylinders on Deere 420 Loader #13
Ok I have a 300cx loader and one of the cylinders started pouring fluid today is there any where I can find a how to on repairing it I'm very capable just would like to not go in blind
   / rebuilding lift cylinders on Deere 420 Loader #15
Thanks to all of the contributors, I have a high level of confidence regarding an upcoming reseal project.
I have a couple of questions regarding re-assembly. Does anyone know the torque setting for the rod nut? Is is advisable
to use removable thread locker on the rod nut?
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A51039)
3-Point Hitch Root...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2014 Nissan Maxima (A50324)
2014 Nissan Maxima...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
