Rebuilding Ford 800 Ford Tractor (821C) Level Problem
   / Rebuilding Ford 800 Ford Tractor (821C) Level Problem #1
catman977
Ashland,Missouri
IH Farmal M
Hello everyone. This is my first post so please excuse my miss spelling. Im very old and trying to restore my 821C, which is a comercial version of an 800 tractor. I rebuilt the engine a couple of years ago completely, but a lot of other jobs pushed the project back a couple of years. The engine sat on a stand covered up in the back of my shop. The rest sat outside. I finally rolled the rear section into the shop and mated the engine to it. I then rolled the front wheel section in and bolted it to the engine, attached the steering rods and the big ones with the balls. My problem is the tractor wasn't level. So I thought maybe the Rear tires were over inflated, which I added air before I rolled it in, not checking pressure. I checked and book said 12 lbs. I took the cores out of the rear tires to let the air out and start over. With the air all out, the engine still has a slope down appearance. It's only level when I put a floor jack under the transmission area and raise it level, then the front wheels are 4 inches off the floor. I thought maybe I bolted the front end upside down, but it can bolt only on one way. Can anyone here tell me what I did wrong?
Thanks for any help Max
   / Rebuilding Ford 800 Ford Tractor (821C) Level Problem #2
Well, that's a puzzle. I'm guessing that yours has the typical swept back front axles, and the wheel spindles out at the end of the axle are sort of swept forward. Like this photo below:
That axle mounts on a center pivot which kind of restricts the amout of mistakes possible. If the axle isn't in there upsidedown, could it be backwards right to left?I
I'd love to see a photo of what yours is looking like jacked up like that.
You might also try the Ford tractor club. They have many free manuals and a great "How to do it" Forum,
Including some photos of axle and frame rebuilds.
Or since you are a member here, you couldrepost your question on our tractorbynet.com on the Vintage FORD forum:
Luck,
rScotty
   / Rebuilding Ford 800 Ford Tractor (821C) Level Problem #3
What size are the tires front & rear? There really is no way to bolt it all back together wrong so I am guessing it was not sitting level when you tore it down and you just do not remember it. The most likely cause would be over size tires on the rears or under size on the fronts
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
