rebuid 743 bobcat hyd. control valve
   / rebuid 743 bobcat hyd. control valve #3
Welcome JWBrown,
What is the complaint?
Leaks?
Creep-down?
Low pressure?
Sticky spool?
   / rebuid 743 bobcat hyd. control valve #4
Welcome to TractorByNet!
I moved your thread to the Construction Equipment forum. :)
   / rebuid 743 bobcat hyd. control valve #5
got any good tricks?
Is it a stacked valve or a monoblock valve.
If the spools do have seals on the shaft, they are there to keep dirt out.
On the stacked valves, you can replace the o-rings between the stacks.
You can't replace spools as they are a precision fit, and the bore of the valve is probably worn.
You can obtain replace valves, that will do the job if they will fit the space allowed.
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2020 Hino 195 16ft Electric Box Truck (A51692)
2020 Hino 195 16ft...
