Mar 5, 2014 / rebuid 743 bobcat hyd. control valve #1 J jwbrown743 New member Joined Mar 5, 2014 Messages 1 Location brownsville ,texas Tractor 743 bobcat got any good tricks?
Mar 5, 2014 / rebuid 743 bobcat hyd. control valve #2 deerseeker001 Super Member Joined Jul 20, 2011 Messages 5,699 Location Central wisconsin Tractor International 2500a with Loader Welcome from Wisconsin
Mar 5, 2014 / rebuid 743 bobcat hyd. control valve #3 wdchyd Elite Member Joined Apr 16, 2010 Messages 3,256 Location Hooksett, NH Tractor Kubota B2320 Welcome JWBrown, What is the complaint? Leaks? Creep-down? Low pressure? Sticky spool?
Mar 26, 2014 / rebuid 743 bobcat hyd. control valve #4 Briana03 Elite Member Joined Jul 23, 2010 Messages 3,255 Location San Diego, California Tractor None Welcome to TractorByNet! I moved your thread to the Construction Equipment forum.
Mar 26, 2014 / rebuid 743 bobcat hyd. control valve #5 J_J Super Star Member Joined Sep 6, 2003 Messages 18,952 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST jwbrown743 said: got any good tricks? Click to expand... Is it a stacked valve or a monoblock valve. If the spools do have seals on the shaft, they are there to keep dirt out. On the stacked valves, you can replace the o-rings between the stacks. You can't replace spools as they are a precision fit, and the bore of the valve is probably worn. You can obtain replace valves, that will do the job if they will fit the space allowed.
