Rear Worklight amperage TC29D
   / Rear Worklight amperage TC29D #1
Typhoon
Southern Illinois
LS MT357HC
Greetings! On my TC29D, there is a rear worklight connector/wiring. I know that when the key is turned on, this connector is energized. My question is, what kind of current will this particular circuit handle? I would like to have 3 55w lights on it, but I don't know the amperage capacity. Does anyone know?
Thanks..
   / Rear Worklight amperage TC29D #2
I would check with your dealer. Most setups on the JD's anyway are only rated for 2 55 watt lights, or about 8 amps.
   / Rear Worklight amperage TC29D #3
I put two lights on my roll bar and hooked them into the plug. The plug itself gets pretty hot after a while. Also when starting and using the glow plugs you have to have your lights off. If I have the tractor lights on and the two on the roll bar I will blow the main fuse.
I would wire, switch and protect from the battery.
murph
   / Rear Worklight amperage TC29D #4
3 lamps @ 55w .. thats 165w.. @12v.. yuo will be pulling just under 14a.
What size wire is it? If it's a larger gauge wire.. probably ok.. however.. the switch may not handle the extra rating. If it was me.. I'd put a 'fog lamp' relay in, and have the relay actuated by that line, and then wire myself a 10ga wire from the battery ( fused to 15a ).
Soundguy
   / Rear Worklight amperage TC29D #5
I believe on a TN those little plugs are 10 Amp. I suspect NH is consistent in the use of that plug's capacity.
Andy
   / Rear Worklight amperage TC29D #6
That answers the question then!
Soundguy
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
Krupp 300 Hydraulic Hammer (A52384)
Krupp 300...
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
