Rear wheels not pulling
/ Rear wheels not pulling #21
NO that's not working correctly. Axel matching is off or the pumps need calibrated. Wheels should turn in unison with equal torque. :confused:
/ Rear wheels not pulling #22
mine spends most of its time moving at idle.. I don't crank the RPM's unless I'm snow blowing or digging (working it).. chasing around the yard it just goes at idle..
mykleh...... I wasn't trying to imply it wouldn't move at idle as mine clearly does. My issue is both axles not providing torque at idle.
Jabonee.......I believe you are right. I did another test this evening. I used a strap and connected the TC to a tree, once the strap was tight I revved the engine and slowly added pedal. Only the front tires spun proving the rear axle is still not supplying enough torque to spin them. I thought about what you said regarding axle matching. I had previously read there was often a problem with the B model TC where one axle would drag (I'm not having this problem). In several instances Bobcat would turn the axle matching off and this would fix the problem. Since I recently purchased this vehicle I don't know anything about its history. Since it isn't throwing a code I assume the axle matching has been turned off. This leads me to your other thought about the pump needing calibration. I read in the service manual where this is accomplished with software. It also mentions that all 4 wheels will rotate when this calibration is performed and the vehicle is on jack stands. I have proven to myself that some torque is getting to the rear wheels just not enough to cause them to spin under a heavy load. My current plan is to take the vehicle to the dealer and have them calibrate the pump. I'm guessing they will also be able to tell if the axle matching has been turned off. Thanks for the ideas.
/ Rear wheels not pulling #24
Can you trace the hoses to the valves you checked....do they go to the front or rear?
/ Rear wheels not pulling #25
If your taking the TC to a dealer request a print out of the "service codes" That will give you a good idea of the units trouble history. Look for low charge psi warnings. FYI turning off axle matching was not to fix a problem but too hide one. :thumbsup:
2019 CATERPILLAR 299D3 XE SKID STEER (A65053)
2019 CATERPILLAR...
BUSH HOG SM60 DITCH BANK MOWER (A64278)
BUSH HOG SM60...
UNUSED FUTURE XKH39-39" HYD MINI 4N1 BUCKET (A65055)
UNUSED FUTURE...
2008 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2008 WINSTON...
78in Heavy Duty Hydraulic Grapple Rake Skid Steer Attachment (A64553)
78in Heavy Duty...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
