Rear Wheel Weight
/ Rear Wheel Weight #1
powershop
Middletown,PA
BX2200
Can anyone tell me why Kubota says not to run rear wheel weights and filled tires at the same time? I have a BX2200 with FEL and wheel weights but need more ballast to do FEL work on side hills. Dan
/ Rear Wheel Weight #2
They don't want you to overload the axles. If you had wheel weights + fluid + something on the three point, you could potentially damage an axle.
Do you have something on the three point & still tipping? You may want to reconsider the slopes you are operating on.
I think you'd be OK with wheel weights & filled tires, provided you took off the weights when you used the three point hitch.
/ Rear Wheel Weight #3
You'd be better off putting on an attachment or making a ballast box for your additional weight. You'll get more "bang for your buck" so-to-speak by getting the ballast further back. By putting ballast 24" behind the rear axle centerline, you'll get the same counter-balance effect with approximately 30% less weight. ie. 100# at the wheels is equivalent to abount 70# 24" back.
/ Rear Wheel Weight #4
rlw,
you're correct for up & down hills, but not necessarily for side to side hills. Although, the more weight on the back end, the better.
Lets say you only have 200# to put on,
If you need a "wheelie bar" use weight off the three point
If you need "training wheels" use weight on the wheels.
/ Rear Wheel Weight
Thanks guys! I now have wheel weights at 70 lbs each. I can use my rear box blade, but was looking for lower center of gravity weight.(filled tires) But the owners manual warns against using both. Dan
/ Rear Wheel Weight #6
Do you have a MMM? Its a good way to add some weight nice and low & wide. I don't know how rough an area you are working, so ground clearance may be an issue.
Definitely put your box scraper on, that will help.
CASE INTERNATIONAL 2208 - 8R30" CORN HEAD (A63291)
CASE INTERNATIONAL...
LOT LOCATIONS (A59911)
2008 Ford F-250 Pickup Truck (A61573)
2008 Ford F-250...
(1) UNUSED 31X13.50-15 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED...
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
