Tires Rear tire flat- lost ballast
/ Rear tire flat- lost ballast #1
bubbu55
North Creek N.Y.
Kioti CK35 HST
I noticed my rear tire on my 35CK hydro was flat and all my ballast leaked out. It seems like the bead broke. I haven't taken the tire off yet. I left my backhoe on the tractor for more weight for winter, my question is should I leave the backhoe on or did that actually cause the tire problem? I have seen many guys leave the backhoe on with no problems. When I do park the tractor, I have to swing the backhoe over to the left to get it in the spot I use to park it, the same side as the bad tire. I think the tire had some kind of molasses in it, not positive. My dealer closed up and the closest one to me is a long way from where I live. Any thoughts?
/ Rear tire flat- lost ballast #3
I'd look for a mobile tire change place near you, then determine what the cause of the flat/leak was and fix it as needed. You may have a nail or other slow leak....I doubt the hoe caused the leak.
Post back results.
The problem is the backhoe is in a tight spot and I have to move it forward to get the outriggers down. The frame of the backhoe is on the ground so somehow I have to try and move it forward with the backhoe and I don't have alot of room to move around.
/ Rear tire flat- lost ballast #5
Can you get a 3 ton floor jack or similar, under the hoe or tractor frame to jack the entire unit high enough for a tire guy to remove and fix the tire in place?
/ Rear tire flat- lost ballast #6
I suspect you have a tubeless tire and there was a small leak either on the bead or in the tread. Air escaped and when it was all gone the weight of the TLB caused the tire bead to separate from the rim. It probably would have made no difference if the BH was removed. If you can lift the tire off the ground with the BH try a ratchet strap around the tire to get the bead to re-seat then fill with air. Once filled you can check for a leak with soapy water. I have also re-seated a bead by spraying a flammable propellant such as starting fluid or WD40 in the tire then lighting it. This is not for the faint of heart and dangerous so I DON'T recommend doing this, just saying it can be done. There are plenty of videos on line showing it can be done and plenty showing the dangers of doing this.
If you do have tubes then the tire will have to come off the rim to pull and patch the tube then reinstall.
It's so tight in that spot that I don't think I can get clearance to get the tire off, so I hope I can move it forward about 4' to get outrigger down. That being said the frame of hoe is on ground and maybe I can somehow lift the frame off ground, and move it forward with bucket of hoe.
/ Rear tire flat- lost ballast #8
If you are able to jack it up a bit and then see if you can air up the tire, it more than likely will hold air long enough for you to drive the tractor out and to a better location to remove it. If you don't have any way of airing it up, I would contact a local tire shop that does mobile repairs and let them take care of it.
/ Rear tire flat- lost ballast #9
...If you can lift the tire off the ground with the BH try a ratchet strap around the tire to get the bead to re-seat then fill with air. ...l.
Good luck with that. I had a front flat (valve stem problem) on my DK and never could get the bead reseated using a cargo strap. I had to take that wheel/tire to a tire place; they used used a Cheetah in addition to a cargo strap to seat the bead. These tractor tires are very stiff. For a rear I would just call a mobile tire place that does agricultural stuff. That's what my dealer did to fill the tires initially. There is danger here: a rear tire/wheel can be quite heavy and could hurt you bad if it fell on you.
/ Rear tire flat- lost ballast #10
Think about it..... You have a backhoe on this tractor..... The BH boom should easily lift the side the flat is on. Put the tractor in neutral, using the BH, lift the tractor and push it forward until you can lower the stabilizer.
I'm guessing you have a leaking tire and when it got low enough it popped off the rim as George said. Get it seated on the rim and aired up, then find the leak and plug it. Then address the issue of replacing the ballast. Not sure why you need ballast with a BH on the tractor though...
/ Rear tire flat- lost ballast #11
Did you ever see an OP move a dedicated loader/bh machine with the bh. I have occasionally moved my CK30hst that way but do it very gently and slowly as it's not really made for this. Also got myself out when a back tire sunk in a hole. You don't want any more pressure on the bh frame and tractor than is needed. Lower your front fel bucket to just above the ground to help with tipping sideways. Drop your boom some with the dipper about verticle and the bucket curled in for a flat bottom cut. You can use the teeth if it slips to much. Lower boom until bucket contacts the ground and then lift tractor slightly to get the bh frame just off the ground. Use the dipper to move forward while lowering the boom to keep contact with the ground. Move about a foot or two and reset again to get the distance you need. You don't want your boom way low or the dipper extended out far. You can use the swing to move the rear of the tractor right or left if needed but go easy on the control. My swing control handle is pretty touchy.
/ Rear tire flat- lost ballast #12
I'd try to put the boom down enough to lift the offending tire slightly then creep forward with the other 3 tires providing propulsion.
Take it easy. And due to the OP's geographic location I'd recommend a tire shop.
I've "reinstalled" a tire with a "broken bead" but that was in the heat of the summer when the tire was "soft".
Not at 24° F.
/ Rear tire flat- lost ballast #13
Not at 24° F.
Yeah, getting the tire back on the rim might require an expert. Moving the tractor is easily accomplished. I suggested using the hoe to move because I didn't figure he could run the hoe controls and the HST pedal at the same time.
/ Rear tire flat- lost ballast #14
I would plan on a lot of switching seats to move a few feet without damaging the flat tire. At his temps the tire may be flat on the bottom but rotate when he puts it in gear.
/ Rear tire flat- lost ballast #15
I have a quick attach hoe that I had not removed in 30 years, until I painted it last year.
For the past 25 years when the tractor is stored, the hoe is set off to the right side.
Never have had any tire issues.
My hoe weighs 2500+ lbs. so I have never felt the need to add any tire ballast.
I change out implements all the time, the backhoe stays on in winter. Bad timing for this, we're getting hammered with snow. I'll try to move the tractor with hoe, it's going to be tricky because I can't swing boom 6" either way. I'm just going to lift it and roll the bucket while tractors in N. Tires still on rim, it's flattened out and leaked ballast.
/ Rear tire flat- lost ballast #17
Sounds like you had beet juice in it, call a farm supply co-op
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2017 International HX620 Quint Dump (A62613)
2017 International...
UNUSED FUTURE PG72-72" HYD PLATE GRABBER (A62130)
UNUSED FUTURE...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
