Snow Rear tire ballast in 3010
   / Rear tire ballast in 3010 #11
https://www.messicks.com/blog/post/Liquid-Tire-Ballast-Chart.aspx
THis site will tell you how much weigh and the amount of water that your tires will hold based on 75% fill factor. Just scroll down to your tire size and read the info.
By the way I wouldnt recommend filling to less than bottom of the valve stem to prevent the sloshing effect that you would get from a 50% fill. It would continue to slosh up and back when you stop and likely cause the tractor to move a bit back and forth.
   / Rear tire ballast in 3010 #12
The dealer up here is Niagara Frontier Equipment Sales... nfesales.com. Maybe they could get you in touch with a distributor out there that has the beet juice. Thanks
Thank guys.
   / Rear tire ballast in 3010 #14
RimGaurd is beet juice, may get slushy in extreme cold but doesn't freeze solid.
I can't get Rimguard unfortunately. If I could get some beet juice, I might put it in myself though.
SIDE PANELS FOR KUBOTA KX040-4 (A58376)
SIDE PANELS FOR...
Bolt Cutters (A57454)
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
1998 Mazda B2500 (A57148)
1998 Mazda B2500...
Rhino DB150 (A57148)
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
