Snow Rear tire ballast in 3010
   / Rear tire ballast in 3010 #11
https://www.messicks.com/blog/post/Liquid-Tire-Ballast-Chart.aspx
THis site will tell you how much weigh and the amount of water that your tires will hold based on 75% fill factor. Just scroll down to your tire size and read the info.
By the way I wouldnt recommend filling to less than bottom of the valve stem to prevent the sloshing effect that you would get from a 50% fill. It would continue to slosh up and back when you stop and likely cause the tractor to move a bit back and forth.
   / Rear tire ballast in 3010 #12
The dealer up here is Niagara Frontier Equipment Sales... nfesales.com. Maybe they could get you in touch with a distributor out there that has the beet juice. Thanks
Thank guys.
   / Rear tire ballast in 3010 #14
RimGaurd is beet juice, may get slushy in extreme cold but doesn't freeze solid.
I can't get Rimguard unfortunately. If I could get some beet juice, I might put it in myself though.
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
New Bolt on Receiver (A59000)
New Bolt on...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
