Ghostrider I also live in Illinois, west central Illinois with Macomb being the nearest town. I have a JD2025r, similar in size to your Kubota. I have Rimguard in my rear tires. The advantage of it is heavier per gallon than otger products and it doesn’t freeze and is non toxic. It’s a beet juice derivative product. The disadvantage is the product is kind of a sticky mess. Normally the only time it’s an issue is when checking tire pressure and they make gauges designed for getting wet. If you get a lot of flats or cuts I’d probably just not fill the tires with anything. I’ve had small tractors for 14 years both with Rimguard and have never had a leak in the back.
I’m not sure of your setup but loaded rear tires is not enough counterweight, some kind of rear 3 point ballast is normally needed also.
