Rear Tire Ballast Fluid?
   / Rear Tire Ballast Fluid? #1
GHOSTRIDER32
Kabota LX2610
What liquid is everyone using in their tires for ballast?
I’m in a medium cold climate. Illinois
   / Rear Tire Ballast Fluid? #4
Northern Indiana and I use -30 windshield washer fluid with Multi Seal Hydro and 1 gal of antifreeze per tire for the protectants.
   / Rear Tire Ballast Fluid? #5
WWAF here in NS, normal coldest it gets here is -20C, very occasionally lower, I've had no problems freezing
   / Rear Tire Ballast Fluid? #6
water and methanol mix in mid TN. area. Zero problems
   / Rear Tire Ballast Fluid? #8
None, here.
For Traction: Plants like a light footprint in summer & chains are better for winter.
For Ballast: A light implement on the 3pt ballasts the FEL more than heavy tires do.
We live in the mountains. Lots of gravel and little clay. YMMV.
   / Rear Tire Ballast Fluid? #9
I have 1550# of RimGuard in the rear tires of my Kubota M6040. Installed by the dealer when I bought the tractor in 2009. My M6040 weighs 10,100# and never goes on any of my lawns.
   / Rear Tire Ballast Fluid? #10
I have the same set up as Oosik and I do occasionally have to drive on the lawn but only after an extended dry spell.
and then I try not to run in the same track twice.
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
2017 Hyundai Tucson SUV (A50324)
2017 Hyundai...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
2015 JLG 2632ES 26FT Scissor Lift (A50322)
2015 JLG 2632ES...
Kubota RTV500 (A47384)
