Rear SCV for 970
/ Rear SCV for 970 #1
Jeff_Indiana
Hi all,
I've got a bunch of little concrete projects lined up around the house for the coming spring, and came across a nifty 3-point concrete mixer that operates off the PTO. It has a hydraulic cylinder for the top link for dumping the concrete.
I need to get hydraulic power (single acting) back to the rear cylinder. Plus, I may be getting a MMM for the 970, so I will need an additional SCV anyway.
Any recommendations? (I already have a dual SCV for the 440 loader that is on the tractor.)
/ Rear SCV for 970 #2
I hear tell that the kits from dealers are getting scarce, start looking now, else everything in the kit can be nickled and dimed together either from the dealer or hydraulic supplier. I can email you a screen dump of jdparts.com BOM and exploded views
/ Rear SCV for 970 #3
You could probably get the rear hydraulic coupler kid which will utilize your front Dual SCV for the loader. And you will not need a hydraulic cylinder to lift and lower the mid mount. My 970 at home uses the 3 point to raise and lower the mower deck and which is why I had to swap out roll bars on my 990 so I could use this type of lift system. My old 4300 used a 3rd SCV to raise the mower deck and this is the way the new mid frames are set up.
