Rear Remotes
/ Rear Remotes #1
RayK
Ontario Canada
Kioti CK20HST-Kubota G1700
Just got a snow blower for my CK20, it has hydraulic rotater and hydraulic deflector, question is can I use my rear BH remotes to power a valve for these cylinders and still have my 3pth operate.
/ Rear Remotes #2
If you connected a separate valve to the remote connections, it would have to be an open center valve. The tractor remote control would be in an "on" position for the fluid to get to the new double valve and this new valve would control your blower rotater and deflector cylinders. With the tractor remote control lever in the "on" position, you'd have no 3pth control. I don't if you ever noticed but when you're using the bh, the 3pth is dead. The 3pth only works when the remotes are in the neutral position.
If you have two sets of rear remotes, you're allready good except for some hoses to the two cylinders of the blower. If you only have one, then it may be easier and cheaper to add the second remote. Use both to make your two cylinder adjustments and when the remotes are back into the neutral position, the 3pth is operable.
Another member might know of a way to use the power beyond circuit but that I'm not familair with.
/ Rear Remotes #3
Not sure here but from what I can find on Bobcat side, looks like the CK20 is only able to fit 1 rear remote valve. No second valve kit available. Adding a 2 spool vavle may be best option.
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2008 IC Corporation PB105 School Bus (A60352)
2008 IC...
Giyi Gy-BK56 QA Backhoe (A60463)
Giyi Gy-BK56 QA...
USC Series 2000 Conveyor (A61307)
USC Series 2000...
