Rear Remotes - Pictures?
/ Rear Remotes - Pictures? #1
Neophyte
Platinum Member
ME
John Deere 3320 eHydro with 300CX FEL
I was wondering if a few of you could post some pictures of your rear remotes and any controls associated with them and their mounting location. I'm trying to get a better idea of rear remotes and how they are controlled on New Holland, Kubota and/or John Deere tractors.
Thank You,
Neo
/ Rear Remotes - Pictures? #2
Sorry, no picture. Do have a recommendation though. The controls for the remotes on my NH TN65 were at the forward edge of the right fender and almost impossible to reach if I was on the ground behind the tractor hooking up an implement. When I bought the MF 1455v the dealer had to install the rear remotes and I made sure the controls were within easy reach so I could make fine adjustments to the tilt and trim cylinders when hooking up. Takes a lot of aggravation out of it when things are convenient.
/ Rear Remotes - Pictures? #3
yea i know what ya mean about not being able to reach the remotes from the back, on my ford 8000 the remotes are up front next to the seat but with the cab ya can reach them, and besides the seat it about 6 and a half feet up in the air anyhow, so its a pain with the hyd toplink to have to climb in and out to adjust it, one of these days i want to add a lever and linkage to one of the remotes so that i can operate it from behind the tractor, but i havent gotten around to it yet, shouldnt be to hard tho i dont think
/ Rear Remotes - Pictures? #4
This isn't a perfect picture, but you can see the "default" placement of the remote valve and lift controls on a TN65.
The green knobbed lever on the right fender is the control for the rear remotes. The lift controls are below it. You can barely see the knob between the gear shift and and the remote lever at the bottom of the pic.
The line connections are on either side of the top link.
The levers aren't not readily accessible from the rear of the tractor, but are quite convenient for me when I'm in the seat.
Rhughes,
Thanks for posting the pic. What implements do you use your rear remote for? Is one enough or should I get two?
Does anyone else have examples of their rear remote and control valve placement that they would like to share?
/ Rear Remotes - Pictures? #6
I use the rear remotes for my disc's and planters as well as my loader. Here is a pic of the rear remotes on my TN.
/ Rear Remotes - Pictures? #7
Lever arrangement on the TN
/ Rear Remotes - Pictures? #8
Lever arrangement on the 1920
/ Rear Remotes - Pictures? #9
Rear remote on the 1920
/ Rear Remotes - Pictures? #10
My new TN65 has only the single rear remote as does the old JD; I can have extras installed if necessary.
On the JD I used them to operate a front mounted blade. The round bailer we use requires remote hydraulics as well.
I don't have a FEL; those generally operate off a dual set of mid mounted remotes.
/ Rear Remotes - Pictures? #11
The TN's run the loader off the rear remotes. When you order a new TN with loader they come standard with the joystick and two remotes.
/ Rear Remotes - Pictures? #12
Neo
My remote levers are located at the right side of the operator station right where your hand normally sits on my Kubota M9000. They operate with just a touch of my finger. The valves are above the PTO shaft behind the operator seat. I do the same thing a Robert and tie wrap my hoses and fittings so that the up and down are always the same.
I use my two remotes on a leveler that my brother and I built. One hydraulic ram moves the leveler blade up and down. The other ram tilts it. Mine looks something like this but heaver.
/ Rear Remotes - Pictures? #13
Actually those are plugs for the tips when they are out. There is a colored ring on the remotes that correspond to the colored plugs so they go in the same way as those four hoses are the loaders.
/ Rear Remotes - Pictures? #14
Robert
That sounds even better. Do the tractor shops sell those or who. I get tired of cleaning the bugs off the hydraulic ends so that would be great.
Eric
/ Rear Remotes - Pictures? #15
Tractor dealers sell them, I just bought a bunch from Lakeland JD in Avon, NY for a couple bucks each. They were hanging on the end of a asile so it was something they stock regularly. I know my NH dealer could order them but they wanted a few dollars more plus my friend works at Lakeland so I just bought from him while I was visiting /forums/images/graemlins/wink.gif
Also, they have a little drain hole in them so any oil can run out and not build up inside the cap. Great for keeping the dust off of them as well as the bugs and anything else that wants to stick to the oil.
/ Rear Remotes - Pictures? #16
Robert,
Good looking tractor.
Here is a shot of the back of mine.
http://www.tractorbynet.com/forumfiles/37-230727-remotes.jpg
The only bad thing about those new holand plastic covers is if you leave your loader plugged in for months at a time it will bend the little plastic caps so they don't close properly anymore. At least all of mine are bent just a hair so dirt can get in.
Have not tried it yet but I bet a heat gun will solve this problem, temporarily until I leave them on again.
I used some of that wire marking numbered tape to label the connections so I get them in the right spot on all the implements. Number 1-4 on tractor and each implement hose. That way up is always up and avoids the old:
Huh....that rear baler door won't open when I press the up direction on the lever.......wonder why.... /forums/images/graemlins/confused.gif
Of course us engineers in the group would propbably end up overhauling the cylinder before we find the simple error.... /forums/images/graemlins/blush.gif
Fred
/ Rear Remotes - Pictures? #17
I have only had the loader off the TN twice in the 3+ years I have owned it so I have no clue if the doors will shut properly anymore. Plus by having the 3rd set of remotes I don't need to unplug any of the loader hoses for my equipment as I don't have anything with more then one up and down function so far. I do like NH switching to the 90 degree elbows on their couplers for their loader hoses. Mine came out straight and it puts a lot of stress on the hose ends. I need to switch them over to the 90 style like all the new TN's have (winter project). Have fun.
/ Rear Remotes - Pictures? #18
I'll have to check them out. I usually try to stay away from the dealerships. It can be a dangerous place to my wallet. When I see all those things that my tractor could do I get inspired and have to get my wife to give me a reality check. Right now I have the bug for a 10' mower. My old 5' mower is a little under sized for the M9000 and it keeps breaking. No/yes/no/yes/no/other priorities/ect. Luckly the wife is good at checking these inspirations. Attached is the M9000 with no attachments /forums/images/graemlins/frown.gif
/ Rear Remotes - Pictures? #19
Sorry pic didn't go through
Eric
/ Rear Remotes - Pictures? #20
I noticed its a "low profile"
basically that is the downward pointing exhaust to reduce overall height?
Fred
2008 KENWORTH T800 QUAD AXLE DUMP TRUCK (A59904)
2008 KENWORTH T800...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
2025 CE SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 CE SB05...
2017 Ford Focus Hatchback (A59231)
2017 Ford Focus...
2016 Ford F-450 Utility Flatbed Dump Truck (A59230)
2016 Ford F-450...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A59230)
2007 Oshkosh...
