Rear remotes- Kioti DK45-HST
   / Rear remotes- Kioti DK45-HST #1
Mark Headley
Randle WA
2012 DK45SE-HST Kioti, JD X758
I have a 2012 Kioti DK45-HST. It has dual rear remotes, the factory stuff. Tractor label says only one is dual acting.
Currently I have a tilt cylinder on the 3-point occupying the double acting ports. I want to get a LandPride blade w/ optional angling hydraulic cylinder, and want to be able to tilt and angle.
What can I do to get two double acting rear remotes? My understanding is the single acting ports wont push and pull.
As a side note, I run a grapple on front and the dealer hooked up a valve block, mounted on the right loader frame, and there's a trigger on the joystick handle that operates the grapple clamp feature.
   / Rear remotes- Kioti DK45-HST #2
I am fairly certain that both valves are double acting. The first valve is a detent valve and is intended to be a supply source for implements that have their own control valves. This valve is a double acting valve, just not a spring return to center valve.
This TBN thread might help you out. Good luck.
Thanks for the info!
I may see about removing the detents in the primary rear remote (as discussed in the link you provided) as I cant see myself having a rear attachment requiring that and its a pain otherwise.
   / Rear remotes- Kioti DK45-HST #4
I have a 2010 dk45 with factory twin rear remotes. Both are double acting. I removed detent ball in one of them for front plow. Left ball in other for log splitter use.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
CAT 973 (A47384)
CAT 973 (A47384)
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
