Rear remotes- Kioti DK45-HST
   / Rear remotes- Kioti DK45-HST #1
Mark Headley
Randle WA
2012 DK45SE-HST Kioti, JD X758
I have a 2012 Kioti DK45-HST. It has dual rear remotes, the factory stuff. Tractor label says only one is dual acting.
Currently I have a tilt cylinder on the 3-point occupying the double acting ports. I want to get a LandPride blade w/ optional angling hydraulic cylinder, and want to be able to tilt and angle.
What can I do to get two double acting rear remotes? My understanding is the single acting ports wont push and pull.
As a side note, I run a grapple on front and the dealer hooked up a valve block, mounted on the right loader frame, and there's a trigger on the joystick handle that operates the grapple clamp feature.
   / Rear remotes- Kioti DK45-HST #2
I am fairly certain that both valves are double acting. The first valve is a detent valve and is intended to be a supply source for implements that have their own control valves. This valve is a double acting valve, just not a spring return to center valve.
This TBN thread might help you out. Good luck.
Thanks for the info!
I may see about removing the detents in the primary rear remote (as discussed in the link you provided) as I cant see myself having a rear attachment requiring that and its a pain otherwise.
   / Rear remotes- Kioti DK45-HST #4
I have a 2010 dk45 with factory twin rear remotes. Both are double acting. I removed detent ball in one of them for front plow. Left ball in other for log splitter use.
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
Round Bale Feeder with Skirt (A50515)
Round Bale Feeder...
2021 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
2021 CATERPILLAR...
UNUSED AGT KFE-20 ELECTRIC STRAIGHT MAST FORKLIFT (A51243)
UNUSED AGT KFE-20...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
