Mark Headley
Bronze Member
I have a 2012 Kioti DK45-HST. It has dual rear remotes, the factory stuff. Tractor label says only one is dual acting.
Currently I have a tilt cylinder on the 3-point occupying the double acting ports. I want to get a LandPride blade w/ optional angling hydraulic cylinder, and want to be able to tilt and angle.
What can I do to get two double acting rear remotes? My understanding is the single acting ports wont push and pull.
As a side note, I run a grapple on front and the dealer hooked up a valve block, mounted on the right loader frame, and there's a trigger on the joystick handle that operates the grapple clamp feature.
