rear remote set up
/ rear remote set up #1
big red 3
East Greenwich RI
Yanmar 220d
Hello
I have an older Yanmar 220d and I'm trying to set up a 3pt log splitter. My question is under the seat, the valve that control the 3pt (brake for up and down)has 2 plugs in it. Are they live and can I use them or what is the best way to add rear remote hydraulics
/ rear remote set up #2
Hi Big Red,
I ran my 3 pt spliter off my loader curl function for years. The dealer that sold me the splitter sold me hose extensions with the appropriate fittings to connect at the loader quick attach. Bungee cord the loader lever to the steering and away you go. Only catch is the curl function for bucket is disabled and with the lever bungeed over the 3 pth arms don't mover either.
I bought a used backhoe from the same tractor model few years ago. The seller and local dealer set me up with another cool way to get aux hydro power. To power the hoe they made me a short hose with male coupling on one end and threaded on the other. This replaced my return line from loader block down to the tranny. That pugged into the female coupling on the tranny I replaced when removing the stock steel return line. The hoe is just plugged into the line with male and female couplings to make the circuit. Everything works as it should, power beyond!
I was thinking this winter how it would be nice if my splitter and bucket curl could work without switching lines. Yesterday I studied the situation.
Bought a female QC to replace one of the males as the QC matched the ones for the backhoe. Now I do the same with my splitter as the hoe. Break the QC lines from loader to tranny and connect the splitter in line. Now everything works as it should as needed.
Keep in mind you must know the direction of flow or the splitter will run opposite.
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
