Rear Remote Pressure Question
/ Rear Remote Pressure Question #1
Haoleguy
Platinum Member
SE Connecticut
JD 5325; Landini Mistral 50
I'm in the process of purchasing a hydraulic tool that is rated for a working pressure of 1500-2000psi. I'm looking to plug this into one of my rear remote sets. I have not yet tested my rear remote hydraulic pressure yet but I believe it will be in the 2200-2300 psi range based on discussion with mechanic familiar with my tractor(Landini Mistral). If it is indeed higher than the tool operating pressure range how is it best to reduce this pressure to 1900-2000 psi?....Thank you, Gary
/ Rear Remote Pressure Question #2
Thank you JJ that's what I was thinking might be the answer. The valve that I saw that is preset for 2000 psi is the following..... Surplus Center - WJL-50-2000 HYD RELIEF VALVE . Any difference in preset relief valves versus dial in the pressure in terms of reliability? Thank you again......Gary
/ Rear Remote Pressure Question #4
No, the factory just has a set number they use for a type of valve. They usually indicate the adj psi range.
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2012 WESTERN STAR  4900 SF (INOPERABLE) (A65643)
2012 WESTERN STAR...
2017 JOHN DEERE 437E LOG LOADER (A64276)
2017 JOHN DEERE...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2005 John Deere 7420 (A60462)
2005 John Deere...
