rear remote issue
/ rear remote issue #1
savagesultin
Savage Harbour, PE
Case Farmall 55
I have a 2009 DX55 and I have two rear remotes. One I'm having an issue with, it will work one direction but when I put the lever in the opposite direction is doesn't work. I have a snowblower attached and one way it will rotate the drum to the left when I push the lever the other direction it won't go back to the right unless I push it hard a couple of times then it will work very slowly. I plan on removing it but thought someone might be able to help troubleshoot it as well. I don't want to replace the valve but might have to.
/ rear remote issue #2
Have you tried the snowblower on the other rear SCV? That is, have you verified it's the SCV and not the snowblower's cylinder?
/ rear remote issue
yes I've switched it from the rotating drum to the chute and same result
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
John Deere 2840 Tractor (A64047)
John Deere 2840...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A65053)
2016 CATERPILLAR...
2013 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A67148)
2013 FREIGHTLINER...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
