rear remote issue
/ rear remote issue #1
savagesultin
Savage Harbour, PE
Case Farmall 55
I have a 2009 DX55 and I have two rear remotes. One I'm having an issue with, it will work one direction but when I put the lever in the opposite direction is doesn't work. I have a snowblower attached and one way it will rotate the drum to the left when I push the lever the other direction it won't go back to the right unless I push it hard a couple of times then it will work very slowly. I plan on removing it but thought someone might be able to help troubleshoot it as well. I don't want to replace the valve but might have to.
/ rear remote issue #2
Have you tried the snowblower on the other rear SCV? That is, have you verified it's the SCV and not the snowblower's cylinder?
/ rear remote issue
yes I've switched it from the rotating drum to the chute and same result
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
