Rear remote flow/psi
/ Rear remote flow/psi #1
jewing3227
Southern, IN
Mahindra 5035 HST
Anyone know what the flow and psi on the rear remote of a 5035 is? I have a couple flow control valves rated at 8gpm and 2000psi max. Just wanting to make sure these are ok or not to use. Thanks
/ Rear remote flow/psi #2
The PSI is 2750, your pump puts out 11GPM. All the 1/2" QDs that I see will flow 12GPM. What are you trying to control? :confused3:
I seen in the manual that the tractor puts out 2750psi and the pump puts out 11gpm. I was not aware if the rear remote sees that much though. I had came across a thread and I could not find it again stating the rear remote flows about 6gpm with about 2000psi. I am putting together a top hydraulic link. I have found a cat 1 top link from Agri Store USA with 11" of movement and double piloted check valves. I have 2 - 3/8" lines that are 36" long. I also have 2 flow control valves that are rated at 8gpm and 2000psi. Pretty much all I need is the 2 quick disconnects along with 2 - 90's. I just want to make sure what I have so far is the correct items. Thanks in advance
/ Rear remote flow/psi #4
The 8GPM will not be a problem, but if the valve is only rated to handle 2000 psi, they will end up failing in some way. The rear remotes will allow that full 2750 psi through.
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A67714)
ALLMAND ECOLED-RIG...
PILES OF TARPS (DIMENSIONS UNKNOWN) (A68842)
PILES OF TARPS...
1996 John Deere 643D Feller Buncher Cut Down Machine (A66734)
1996 John Deere...
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
CAT 330DL Excavator Grapple (A68134)
CAT 330DL...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
