Rear remote flow/psi
/ Rear remote flow/psi #1
jewing3227
Southern, IN
Mahindra 5035 HST
Anyone know what the flow and psi on the rear remote of a 5035 is? I have a couple flow control valves rated at 8gpm and 2000psi max. Just wanting to make sure these are ok or not to use. Thanks
/ Rear remote flow/psi #2
The PSI is 2750, your pump puts out 11GPM. All the 1/2" QDs that I see will flow 12GPM. What are you trying to control? :confused3:
I seen in the manual that the tractor puts out 2750psi and the pump puts out 11gpm. I was not aware if the rear remote sees that much though. I had came across a thread and I could not find it again stating the rear remote flows about 6gpm with about 2000psi. I am putting together a top hydraulic link. I have found a cat 1 top link from Agri Store USA with 11" of movement and double piloted check valves. I have 2 - 3/8" lines that are 36" long. I also have 2 flow control valves that are rated at 8gpm and 2000psi. Pretty much all I need is the 2 quick disconnects along with 2 - 90's. I just want to make sure what I have so far is the correct items. Thanks in advance
/ Rear remote flow/psi #4
The 8GPM will not be a problem, but if the valve is only rated to handle 2000 psi, they will end up failing in some way. The rear remotes will allow that full 2750 psi through.
