Rear Blade Rear plow blade carnage
   / Rear plow blade carnage #21
Were you "pushing" with the rear blade;that's a no-no;designed to pull not push.No trip somethings got to give.
Hmm, I have to disagree with this as a blanket statement. Certainly it's easier to do damage to both the attachment and the tractor itself plowing in reverse, but with a 3-pt rear blade on a CUT, there's no trip mechanism in either direction, whether pushing or pulling. :)
In fact, virtually every 3-pt rear blade I've seen is expressly designed to rotate for backwards use in reverse, and it can be a very effective way to plow when done correctly. Also, consider the proper use of a 3-pt box blade. Would we also say that it's wrong to grade in reverse, or back fill in reverse, with a BB? Nope. Every 3-pt box blade I've seen for a CUT has both a front and a back cutting edge and mold board. Yet we can damage the attachment, or the tractor's lower link arms and transmission case by working in reverse as quickly with one of those. IMO, the direction of travel isn't the issue. Rather, it's properly matching the attachment to the tractor's size, weight and power, and knowing the limits of both for a given task and conditions.
   / Rear plow blade carnage #22
I would think that going forward would potentially do more damage as you might tend to go faster and farther in that direction.
   / Rear plow blade carnage #23
I have a light-medium duty blade which worked great with a 25 hp garden tractor but when I put it on a 45 HP cut things started to bend very fast even though I behaved with it. Now I am almost afraid to use it.
   / Rear plow blade carnage #24
I just finished blading snow off my 450' driveway, which goes downhill at 19% grade. My 25 HP Kioti CK2610HST can get rolling. So far, no rocks, but I was knocking around frozen in, solid ice chunks the size of two healthy Virginia hams. (did I use the word "healthy" and "Virginia ham" in the same sentence?)
My blade is an EA 84" 6-way and I certainly don't baby it. Seems to be built like a tank. Guess I'll find out for sure when I hit my first big rock, LOL.
   / Rear plow blade carnage #25
I can see why the OP never felt it.....it wasn't welded. At least not in the sense of 2 pieces being joined together. I think some flex seal and flex tape would have held better. :laughing:
   / Rear plow blade carnage #26
I can't see what that has to do with it. That break would have occurred whether pushing or pulling, had he hit the same type of obstacle.
The concern about pushing is for the 3Pt hitch system itself: the 3PH is far more robust in the pulling direction than it is when pushing.
   / Rear plow blade carnage #28
All of my blades have been used pulling and pushing, depending on what needed to be done.
Didn't matter if it was pushing dirt or snow if push was the easiest way it got pushed.
   / Rear plow blade carnage #30
Looking at picture again... It appear to be it was pulling and not pushing ( observe angles of bends).... And that there was no penetration at weld joints....
How it was being used is non issue, it was destined to fail no matter if it was handled with kid gloves or beat on with sledge hammers....
Dale
Service Truck (A59230)
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
10' CONTAINER (A52706)
500BBL WHEELED FRAC TANK (A58216)
500BBL WHEELED...
ONAN DNAF-3383022 PORTABLE DIESEL GENERATOR (A52709)
ONAN DNAF-3383022...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
