Rear Blade Rear plow blade carnage
   / Rear plow blade carnage #2
Were you "pushing" with the rear blade;that's a no-no;designed to pull not push.No trip somethings got to give.
   / Rear plow blade carnage #3
Did your dealer sell it to you or was it an internet purchase? Sorry I dont have any experience with this brand. Very unfortunate to have this happen in snow season :(
   / Rear plow blade carnage #4
Looks like a cheaply made blade. Thin material and crappy welds. We can clearly see that a full bead of weld had no penetration at all.
I think you may need a heavier duty blade for the Branson. Those tractors are very heavy and put lots of traction on the tires, so the implements need to be up to the task at handling all the forces.
   / Rear plow blade carnage #5
Hard to believe you felt nothing....but looks bad. I have seen blade bend before they break something was not welded very well.
   / Rear plow blade carnage #6
Yikes! Sorry to see that. Had to have been a rock. What speed were you going and was it down a steep grade?
   / Rear plow blade carnage #7
"Heavy Duty" everywhere except where the strength is needed. Looks like a flesh wound. Tack welded but not 'welded'.
   / Rear plow blade carnage #8
HF 90a glue gun. Could be a warranty issue, carefully document poor welds. If not, cut and repair as neccessary. Hopefully not with a glue gun, but an actual welder. On the bright side, better the damage happened to the blade, rather than the tractor.
   / Rear plow blade carnage #9
Oh crap.... And I was seriously contemplating purchasing that particular blade/design in 48 or 54 inch for behind my SCUT... As a alternative to the cheap crap at TSC...
I would send pictures and complaint directly to BE corporate (yes it's also chinese import) ....
Dale
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
Chariot 12' Box Trailer (A59814)
Chariot 12' Box...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
