Maibox
- Joined
- May 17, 2012
- Messages
- 125
- Location
- Winona, MN
- Tractor
- Kubota L3940; 1942 Farmall H (for sale)
Looking for some advice. My L3940 needed its 50 hour service and I had ordered a front blade. I had the dealer come pick up the tractor with the idea that they could hook up the blade and I could save delivery. I decided while it was there to have two LED's mounted to the ROPs. I know I could have done it myself but laziness won out.
So I went to pay the other day and they showed me the lights. They basically came off the right side of the seat and wired up to a switch. To mount the switch they drilled holes in the ROPs about 12-18 inches or so up on the inside and screwed on a 4-5 in long by 3/4 inch wide piece of metal at a 90 degree angle to the ROPS-facing forward. I can't recall if it went all the way through or if the holes are just on the inside. They mounted a switch to end of the piece of metal. I didn't get a close look to see how they waterproofed it. It basically sticks out from the ROPS about 3 inches or so with the switch in the end. I was bit surprised they didn't mount it on the fender or somewhere else. They also appear to have drilled through the top of the ROPS to attach the lights. By the way, labor on it was about $300 (I don't know the shop rate). I haven't said anything and that's why I am posting.
Is this a normal place to mount a switch? It seems strange to have it sticking out at shoulder height on a piece of metal. I also couldn't tell how they waterproofed it or the rest of the wiring. Is it normal practice to drill through the top and bottom of the ROPS to attach the mounting brackets?
If not, suggestions on how to deal with this? The holes are already there? If I have them move the switch to a better place, what do we do with the holes in the ROPS?
Looking for suggestions (other than don't ever let them work on my tractor again).
As an aside, instead of replacing the hydraulic connectors on the hoses to the blade, they replaced the Kubota third function connectors on the tractor to match the connectors on the blade. When I asked how I was going to hook up my grapple, they told me I would need to change back out the connectors. I mentioned that it sort of eliminated the "quick" in quick-attach. The said they didn't know whether I had anything that used the front remotes and they didn't have the Kubota connectors in stock--to which I replied, why would I have them and why didn't you call to ask? They are going to replace the Kubota connectors and put Kubota connectors on the blade hoses. We will see how they address this on the invoice. This issue makes me question the light mounting even more.
Thanks in advance.
Thanks in advance.
