Rear Inverted Snowblowers 2019
   / Rear Inverted Snowblowers 2019 #371
That is a pretty dated design, They work, but not well. Over here, they sell for $500 used.
   / Rear Inverted Snowblowers 2019 #372
Hadn't seen anew single stage pull type or push in many years.
   / Rear Inverted Snowblowers 2019 #373
Those V blowers are very common in northern Europe, cheap and if it's well designed they work well enough, but of course it's not a two stage so it has limits.
   / Rear Inverted Snowblowers 2019 #374
I would just as soon have rear facing especially if doing any back and forth. A push back blade works well that way too.
I totally agree with with you, for short distances.
Of course short is relative, for some it might be 20' and for some it might be 100' or 200' or 500'. I would happily drive back and forth for a several hundred feet, using a rear facing blower and use a push blade or front mount plow for other areas. I suspect this arrangement is the best for your needs, conditions and equipment. That is the most important consideration. MY conditions and equipment are not the same as yours. Therefore our needs are different. It sometimes seems that people think their way is the best or only way to deal with snow. We live in different parts of the world, have hugely different conditions and equipment, so there is no best solution that fits everyone one and every condition.
A rear facing blower is the least expensive option, the inverted is more $ and the front mount is the most expensive.
It is important to note, that the difference in price gets a LOT bigger with the size of the tractor. For my tractor, where I live, a new rear facing 72" blower is about $4,500 CAD, an inverted blower is in the range of $6,500 and a front mount blower is in the range of $18,000 CAD and up, depending on whether or not your tractor has a mid mount PTO. If not, the cost goes up. Yes, you can get a front mount blower that runs from the rear PTO, with a subframe or hydraulic power pack but I don't think they are a lot cheaper than the frame mounted front blowers, plus that ties up both ends of your tractor.
So back to the same old issue. What is the best solution for one person, is not even close to the best for the next! Your needs and conditions are different than mine and both of our needs and conditions are different than most others. My setup could be the worst combo for your needs and yours could be the worst for mine.
I may arrange supply of the snow blower shown in the pics. It blows to the either side. I'm dealing with the Lithuanian factory which produces them. They are pretty well made, fit big range of tractors, work good. Let me know if there is an interest.
Main tech specs: weight 430 kg; working width 2,25 m; tractor power required 45-110 hp.
As Airbiscuit stated, this is an old design concept and does not work well, in my opinion. This design depends on the blower housing, funneling the snow into a blower fan. I have an 84" inverted blower, with an auger that is full width and powers the snow into the fan but sometimes the fan will not keep up to the amount of snow the augers push into it, so I have to slow down. This design will be the opposite, especially with wet or heavy snow. The housing may not be able to feed the fan fast enough or the snow will stick to the housing, instead of being powered into the fan.
   / Rear Inverted Snowblowers 2019 #375
   / Rear Inverted Snowblowers 2019 #376
Do you have any links to videos of them in operation. I've only found one that is using a very old blower, with a very old tractor, lol.
Edit. I must have posted just before you did. So now I will check out the video you linked.
   / Rear Inverted Snowblowers 2019 #377
   / Rear Inverted Snowblowers 2019 #378
Do you have any video links to tractors in the 20 hp to 50hp range using these blowers?
   / Rear Inverted Snowblowers 2019 #379
I'm curious to see what you use for a snowblower. Please post some pics of what you use and consider to be the best setup for your tractor and your conditions. It will be interesting to compare to what we use.
   / Rear Inverted Snowblowers 2019 #380
A small V blower
2015 Dodge Journey SXT Van (A56859)
2015 Dodge Journey...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3 Ton Crane Service Truck (A55973)
2017 Ford F-550...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
