Rear Inverted Snowblowers 2019
   / Rear Inverted Snowblowers 2019 #161
I have found that they can work ok but will eventually plug. We just had a slop storm and i could blow the areas i had not cleared during the first part of the storm . the areas that i had cleared just had a shallow wet snow / slush combo and i could not keep the chute clear so it was rear blade time.
With regard to the later question about 16 inches of snow. Like others have said if you can drive through it you can blow it. !6 should be easy
A couple of days ago I got about 7" of heavy wet snow and then it started to rain. Yuck!!!. While I was plowing this stuff, it would just roll off the end of the plow in large blobs or just refuse to slide off. Nasty stuff to plow. I know my rear facing blower would probably not work in this stuff unless I went at a snails pace and kept the RPMs way up. Even then I'm sure it would keep plugging up.
Got me thinking about what you guys with inverted blowers do in circumstances like these.
   / Rear Inverted Snowblowers 2019 #162
After I posted I went outside to start clearing snow around the buildings and while I was doing that, the snow kept dumping. After a couple of hours I decided I better plow the driveway before it got too deep. Too late!! When I started on the driveway the snow was 24" (measured) of heavy wet snow. By the time I got to the bottom (1 mile) and back up there was another 12" of heavy wet snow. Game changer!!! My only chance was the rear facing 75" Meteor snow blower. But it would not blow that heavy wet crap. With the new tractor and the improved HP, I never plugged the blower chute but the snow was so heavy it would just build up in front of the blower and not go through the fan (chute). I spent 8 hrs fighting a loosing battle and the whole time the snow kept falling.
When I got home I found the power went out at 9 am, while I was fighting the snow and it finally came back on tonight at 6 pm (33hrs). In the end we got a dump of 1.2M (4ft) in 24 hrs, according to my neighbor that measured it. According to my non measured observations it was well over 3'. I've almost got my driveway and my neighbors opened up and now its snowing again, with a forecast of another 12".
I just spent about 8 to 12 hrs plowing in reverse, looking over my shoulder and NEED a better solution.
This snowfall is unique and not likely to happen again in my lifetime but when I get a new blower I want to make absolutely positive that it will handle the mess I had to deal with over the last few days.
I see your pics (and thank you very much for those) and think that is close to what I went through today, trying to get to get to my neighbors. I couldn't make it up their driveway with chains on all 4's and nothing dragging in the snow. But I'm positive I could pull an inverted down the driveway in those conditions.
The biggest concern is whether the snow will build up in front of the blower like mine did today.
   / Rear Inverted Snowblowers 2019 #163
I have never used an inverted blower so this may not apply.
We get some heavy storms here from time to time. One thing I have found that helps get thru the deep snow is to hold the blower off the ground 6" to 12" depending on the overall depth of the snow and consistency of the snow. That applies more weight to the back of the tractor so you can cut your way thru the deep snow. Once you get a path cut thru then go back and clean what was left.
Quite often if snow is building up in front of the blower it is an indication you are going too slow. Raising the blower will reduce the cubic feet per minute of snow you are blowing so, depending on conditions, you can increase your speed so you out run the snow building up in front of the blower. Each blower/tractor combination will have it's ideal cubic feet per minute but that will vary by snow conditions. The deep storms challenge us to find the ideal setting for blower height and speed to efficiently get the job done.
And sometimes we get that rare storm that doesn't have an efficient way to get it cleared so we just muscle through as best we can.
   / Rear Inverted Snowblowers 2019 #164
The last 2 days have been the most challenging conditions I have had to deal with and I'm not finished yet. Plus more snow is on the way.
Yesterday I had better success than the day before and I tried all of the suggestions you made. To my surprise, sometimes it was better to go faster but not always. There didn't seem to be any particular "happy place" to set the blower height or speed. I ended up having to go back and forth a lot. Lifting the blower to try to blow off the top of the pile that built up and then back up, to take another run at it with the blower lower.
One thing I know for sure. Now that I have 5' to 6' banks on both sides of the driveway, I am going to have blow pretty much every snow event ......... going backwards and looking over my shoulder.:smiley_aafz:
If any of the local dealers had an inverted blower that was wide enough for my tractor (84"), I would see about a trial run and then buy it if all went well. But around here there are very few blowers for sale (probably none left after this last storm and no dealer has ever brought in an inverted blower. At least not the ones locally.
After my personal experience with a 75" blower that has a 21" fan that is 7" deep, I now know to get one with a bigger diameter, deeper fan.
Well I'm off to do some more plowing and blowing. Hopefully buy the end of today I will be able to get my 4x4 truck up and down the driveway.
   / Rear Inverted Snowblowers 2019 #165
   / Rear Inverted Snowblowers 2019 #166
That does apply to inverted blowers Reb954. I did that this morning while clearing my neighbour's driveway. Yesterday the snow was very dense and I had conditions similar, but not as deep as Hillbilly's. I plugged the blower similar to what Hillbilly describes three times. I finally was able to keep it going continuously by regulating the intake via the tractor's speed. I went down to another neighbour's to clear his yard for the annual New Year's Day party they have for our road. He has an 82hp, 4WD Ford 6610 with a rear blade but I end up clearing his place at least once a year because it gets too much to do it with his blade and bucket. The area I cleared had over 2' of that heavy, cement-like snow. I tried it going forward and could have done it but I could tell I might wreck something. So I did the first pass(it's only 100' long) by backing up and pulling ahead. Once I had that channel open I could do it all in one pass.
They have not cleared our road and only 4WD trucks can manage it. So neighbours walked down to get to the party and my one neighbour and wife drove down on their tractor. I put concrete blocks in the truck and was able to drive. But we left before dark in case we got stuck coming back home (an uphill drive). It was fine but if we met another vehicle we likely would have both been stuck as we could not pass each other.
Yesterday I was unable to get to one neighbour's(it is where the photos earlier in this thread were taken) I always clear because trees were down over the road. So I did a couple of passes for two other neighbours' on the way home.
Today it was -3 C and someone had cleared the downed tree. So I was able to get to the neighbour at the end of the road. The colder weather made a big difference. The snow was likely as deep but so compact that the tractor was likely 3" or so higher by driving over it, making it only as deep as the top of the front axle. I had to raise the blower to do the first pass and after that I could take the full depth. In all I did three passes over the whole area to progressively shave off the snow.
I realise inverted blowers are not the right choice for everyone. However, each year I am more confident they are the best choice for my situation.
Our storm was not as dramatic as Hillbilly's but we must have had at least two dozen momentary outages in the last few days and a few lasting 1/2 to 2 hours. They are cause by snow-laden limbs falling. Most of the snow is off the trees now and every thing is stable today. But the road people have still not cleared our road. No doubt they are busy with the main roads. We are a class "D" on their schedule!
   / Rear Inverted Snowblowers 2019 #167
KCO, would love to see a video of you in action!
   / Rear Inverted Snowblowers 2019 #168
Today was totally different!! The temps this morning were -10C and I could easily go through the snow with the blower. No plugging and I could vary the speed to prevent build up in front of the blower. What a difference cold weather makes even on snow that was heavy and wet, then rained on. Today it was almost like powder.
My next door neighbours were overwhelmed by all this snow. Even with all the equipment they have, nothing was working for them. Yesterday I opened up their driveway with the blower but really struggled to get up their steep (15%) driveway. After the first pass it was easy coming downhill. I went to check on them today and the wife was in tears. They've been struggling to keep their animals fed and watered. They had to hand dig pathways to the various animals and carry water and food to them. I took the blower and ran backwards through some of their paths, to open them up, so they could get their tractor in and out. Some of the banks were over 6 ft high but the blower went through them easily. Definitely a job for a rear facing blower.
I've been backing up, looking over my right shoulder for 3 days now. I think my neck is frozen in that position and I will never be able to look to my left side again.:laughing:
I think next year I will get an inverted blower for the normal snow events and keep this one for the crazy events like this one.
PS if this is deviating from the thread intent, I can start another thread about this storm event. I took some pics today but didn't want to lead this thread astray any more than I already have.
   / Rear Inverted Snowblowers 2019 #170
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
401 (A52706)
401 (A52706)
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
2008 GMC C5500 Landscape Truck (A56858)
2008 GMC C5500...
CFG Industry QK16R Mini Excavator (A57149)
CFG Industry QK16R...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
