Rear Hydraulics
/ Rear Hydraulics #21
Can you post pics when your done. Let me know how you like the handle by your right leg I'm still debating it. When I do mine I'm prob gonna go ahead and do the dual for the top and tilt
/ Rear Hydraulics
Ill probably end up with the dual, and possibly the front - just doing as I can afford. Ill try and doccument as I go, if I can figure out my phone camera.
/ Rear Hydraulics
Parts arrived - been reading the instruction - several times. I think I know how the install should work, but I will read them again. Anyone done this recently that can remember any issues or tricks?
Thanks
/ Rear Hydraulics #26
One of the first steps is to remove the seat. The job would be impossible if you don't. I did not however remove the loader control lever and found that it really did not get in the way, so you could skip that step.
Let us know how you do.
/ Rear Hydraulics
Thanks - Ill try and get a few pictures as I do this - should be good for a few laughs.
/ Rear Hydraulics #28
A tip when removing the seat; fasten seat belt across it and pull it tight. This keeps the seat from tipping, folding on you when trying to lift off the tractor.
/ Rear Hydraulics #29
I thought of another issue. Some of the torques requirements in the instructions were not correct. If you have a bolt size / torque guide, refer to it.
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2009 STRICK 53X102...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
Patterson water pump (A59230)
Patterson water...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
