Rear Hydraulics
/ Rear Hydraulics #21
Can you post pics when your done. Let me know how you like the handle by your right leg I'm still debating it. When I do mine I'm prob gonna go ahead and do the dual for the top and tilt
/ Rear Hydraulics
Ill probably end up with the dual, and possibly the front - just doing as I can afford. Ill try and doccument as I go, if I can figure out my phone camera.
/ Rear Hydraulics
Parts arrived - been reading the instruction - several times. I think I know how the install should work, but I will read them again. Anyone done this recently that can remember any issues or tricks?
/ Rear Hydraulics #26
One of the first steps is to remove the seat. The job would be impossible if you don't. I did not however remove the loader control lever and found that it really did not get in the way, so you could skip that step.
Let us know how you do.
/ Rear Hydraulics
Thanks - Ill try and get a few pictures as I do this - should be good for a few laughs.
/ Rear Hydraulics #28
A tip when removing the seat; fasten seat belt across it and pull it tight. This keeps the seat from tipping, folding on you when trying to lift off the tractor.
/ Rear Hydraulics #29
I thought of another issue. Some of the torques requirements in the instructions were not correct. If you have a bolt size / torque guide, refer to it.
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2007 Ford F53 Landau 3645DS 36ft. Class A Motorhome (A61574)
2007 Ford F53...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2019 Ram ProMaster 2500 Cargo Van (A61573)
2019 Ram ProMaster...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
