? Rear gearbox fluid
   / ? Rear gearbox fluid #1
Anonymous Poster
Epic Contributor
I have a "grey" Kubota B5000. I'm trying to find out what fluid goes into the rear gearbox, and to what level should it be filled? (There is a plug in the side of the housing approx. half-way up - looks like this would be the fill level?) I believe this would be the same fluid for the 3 point lift also.
   / ? Rear gearbox fluid #2
Yes, that is the level it should be at (hole in middle). I just got some sight-windows that screw into that hole, and I can visually check the level without having to remove that nut.
I got my Gear Box oil at Western Auto ( I think it's 80 or 90 W).
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
   / ? Rear gearbox fluid #3
In my tractor(L3000), the rear axle/3 point and transmission is all hydraulic fluid. The front axle is 90w gear oil.Maybe its different for your tractor though.
Paul
   / ? Rear gearbox fluid #4
Greykub
I would use <font color=orange>Kubota</font color=orange> UDT oil.
Use a straight SAE 80 or 90 oil. Do not use hypoid or any oils with additives which create problems for your hydraulics.
   / ? Rear gearbox fluid #6
Hi ya
ya bring up a good point and one i'm trying to work out too most of the time ya see 80W (or there abouts)in gears ,diff's ,front axles,but not in hydros or 3 point ..even off the top of my head i can't recall puting that hevey oil in a back end before 10w or 15 w or uni oil yes many times but 80w for a hydro pump ?????????
catch ya
JD Kid
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
