Mowing Rear finish mower sizes on BX24
   / Rear finish mower sizes on BX24 #1
harleyguy302
Nebraska
Kubota BX24
I read recently some discussions on here about people using rear finish mowers rather than the belly mower. I was curious about what sizes people are using behind a bx. I have a rough cut rear mower now but am thinking of switching to a finish mower now that the property is under control. I believe with the finish mower I could then use it more on my immediate yard and give the old rider a break.
   / Rear finish mower sizes on BX24 #2
There are finish mowers made for the BX by King Kutter and Woods. I believe they are 4' mowers. Your tractor has enough hp for a 5' mower, but weight could become an issue.
Will
   / Rear finish mower sizes on BX24 #3
I have a 48" Sitrex finish mower and it works fine. I decided on that size because I have a few trees that are just ove 4 feet wide and I wanted one to fit in between, And, I found it used for a great price!!
Deano
   / Rear finish mower sizes on BX24 #4
Ihave a 60" mmm and wish i got a smaller mower just because of flat terain.I don't have. I've got some bald spots at first but now all better for now.
   / Rear finish mower sizes on BX24 #5
5 Feet
I read recently some discussions on here about people using rear finish mowers rather than the belly mower. I was curious about what size people are using behind a bx. I have a rough cut rear mower now but am thinking of switching to a finish mower now that the property is under control. I believe with the finish mower I could then use it more on my immediate yard and give the old rider a break.
   / Rear finish mower sizes on BX24 #6
I pull a 60 inch Kubota finishing mower behind my BX2350 that I am quite happy with. I was offered a 72 inch unit for the same money but turned it down because I thought it was too much mower for the tractor. The two factors that I considered most were the weight and horse power at PTO. You should be able to compare these on your tractor manual and the stats for your mower. Best of luck with your purchase.
   / Rear finish mower sizes on BX24 #7
I pull a 42" rear mower for early season mowing, then follow up the rest of the mowing season with my 54" MMM...Reason I use a 42" mower is because it's the one I had with a previous smaller Kubota.
Don
I just recieved a flyer from harbor freight today and they had a 5ft finish mower for under $600. I think it was made by central machinery. Has anyone had any experience with this one? I know it's probably back to the old "you get what you pay for" thing, but sometimes you just never know.
   / Rear finish mower sizes on BX24 #9
Have you seen it ? Last time someone posted about it and I made a comment about the cheesy wheels on it.
   / Rear finish mower sizes on BX24 #10
The Woods 54" mower seems a good match for the BX. Here is one mounted that has seen lots of service! The friend that owns this one mows acres of Christmas trees with it, and needs the rear discharge since grass clippings will kill the lower branches of his trees.
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
