rear end wobble L2850
/ rear end wobble L2850 #1
jeff burgess
kubota L2850
Hello,
My tractor has developed a wobble. When driving on a hard surface it can be felt once per rear tire revolution . I'm pretty sure the problems on the right side. I used the tractor for a large drive way project this fall and did a lot of pushing and loading with it .
Thanks for any info
jeff b.
/ rear end wobble L2850 #2
Do you have loaded tires? If so check the level.
/ rear end wobble L2850 #3
Did you check the torque on the lug nuts?
No my tires are not loaded but I guess I was assuming the worst right away like a bearing problem. I will check my tire pressure and lug nut troque first thing Sat. morning. Thank you for the replies.
Jeff
/ rear end wobble L2850 #5
Tractor tires don't run true. My BX has done the same thing since new. Nothing to worry about.
/ rear end wobble L2850 #6
I 've had the machine for twenty years and have never noticed it before . It seems to make a little noise at the same time as the wobble and its definitley in the same spot every revolution. Thanks for the info I'm just going to make sure it doesn't get worse I guess.
thanks again
Jeff
no tires are not loaded and the lug nuts are torqued
/ rear end wobble L2850 #9
I would get the back end off of the ground then grab onto the tires and see if you can feel any play in them. Go from there and check for loose bearings or weak, cracked metal.
